Any One Know How ??
/ Any One Know How ?? #1
William Hayes
JD 250 Skid Steer
Hello, I have a JD 250 skid steer, and I have a boom "cylinder" seal leak, on the right side, I have a kit for it and tried to find out how to romove the shaft from the houseing, it has the split ring and I removed that, I tried to push in the piece that the c ring was on, and it will only go in maybe 1/4 inch, sounds like it is hitting something. I am a little dumbfound, any one have any idea ?? I asked the local dealer well they looked at me funny like I'm some kind of idiot, and said bring her in and we'll fix er up, I bought this unit from them paid over $25k new, I though they would have a little respect, but please any help would be great, thanks everyone.....
/ Any One Know How ?? #2
:welcome:
Does it look like this schematic/drawing? Found it in jdparts
Looks like two split rings.
It looks similar to that one, mine has a wleded end cap, and the other end of the ram has the same block with the hole in the middle, but there is only one split ring, I don't see any other one's, on the coller that goe's around the ram shaft. if there is one I don't see it. thanks for the help,
/ Any One Know How ?? #4
Go to jdparts (free but need to sign in) and search for 250 (a list will come up and there are several different 250 skid steers to look at). You may land on the one you have and get some help that you need from viewing the parts list and schematics.
I had done that, But will try again, never know may see something that I did not notice befor. thanks
Say where or what did you find this under in jd parts, I just get 1 asmbly pic and not even close to yours, but I only see 1 snap ring, I will keep looking, but if you have a part number that you used or ? that I couls use it would be great, thanks,
/ Any One Know How ?? #7
what do you mean by split ring?
snap ring? Circlip?
images
some times it takes a lot of effort to get the the rod seal out of the cylinder
repair links
How To Rebuild Or Repair Tractor Backhoe Hydraulic Cylinders
post some pictures of the rod seal end and we will have a better idea how to help you.
tom
Thanks for the help, I don't have any pic's at this time, I'm at work now. but all I see is the main out side cylinder / and the center shaft / there is like a coller that goe's around the main shaft and the out side caseing, there is a ring with 2 holes on it, it looks like it only keeps it is on from going in to the out side caseing, I removed the ring, then tried to slide the coller into the out side caseing, it only goe's in maybe 1/4 inch. some one said to slide it in 1 inch and the put in the orange plastic piece from the rebuild kit, then slide out the whole shaft. ????? I dont see anything the put the plastic piece into,
hope you under stand what I mean.... this is new to me... thanks for the help....
/ Any One Know How ?? #9
dose the end of the cylinder look like this
link to thread
http://www.tractorbynet.com/forums/hydraulics/168137-hydraulic-cylinder-repair.html
snap ring type
or like this one
link to article
Hydraulic Cylinder Repair : How to Disassemble, Rebuild or Repair Hydraulic Cylinders
The second is a spanner set up you can see how it unscrews inthe article and how to build the wrench.
Some time you have to assist the seal out by pulling the rod straight out.
Some times you can un hook the hydraulic lines drain the cylinder and use the piston and rod as a slide hammer to perswade it out again be careful.
I've used come along's, air (be careful its easy to launch the rod and piston), or even a portapower to pump it out. Don't use equipment hydraulics it outs out too much flow you will lanch it for sure.
tom
/ Any One Know How ?? #10
I found it in jdparts, under Model 250
Takes you to a list where 240 and 250 skid steers is found.
Going there, and under alphabetical "B" for boom, find a break at serial numbers 925239.
Going to the higher s/n, can find this pic.
/ Any One Know How ?? #11
I know exactly what you mean, But I need to see pictures of your cylinder or your serial number.
I detailed some info in this thread: JD Hydraulic Cylinder Rebuild Help? - TractorByNet.com
Thanks for all of the help everyone, I now know what needs to be done. with the out side ring clip off, I can only slide the gland in 1/4 inch, not far enough to see the in side grove that the orange plastic piece goe's in to help keep the 2nd ring from expanding. My question is how hard can I be hitting the gland inwards with out recking anything ?
/ Any One Know How ?? #13
Pretty hard I would guess. There is nothing in there to hurt.
/ Any One Know How ?? #14
William , have you loosend the lines so hyd oil and air can escape? do that then using a brass drift punch try to tap the gland into the barrel. there is an intrenal split ring that you wont be able to see , that is wear the orange plastic ring comes in . pound (tap) the gland in just far enuff to expose the grove in the barrel that the orange ring fits into , problably more like a 1/2 inch . the orange filler ring alows the internal ring to slide by the grove and the gland and rod to pull out of the barrel .use the rod as a sort of slide hammer to knock the gland out of the barrel.
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
Lifts (A61567)
Lifts (A61567)
2015 Chevrolet Traverse SUV (A61574)
2015 Chevrolet...
2017 Ford F-150 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
2015 Audi Q3 AWD SUV (A61574)
2015 Audi Q3 AWD...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
