Any strong opinions on King Kutter Rotary Mowers?
   / Any strong opinions on King Kutter Rotary Mowers? #1
defranks
Crab Orchard, TN
Branson 4220
I'm building a house on 20 acres in eastern Tennessee. The property is wooded, but it was likely logged 50 or 60 years ago, as most of the trees are under 18" in diameter.
I'm looking to clear the underbrush and saplings from between the larger trees, leaving the woods more open than they are. I did the same thing in Washington before moving here using a DR brush mower to knock down small saplings, lots of rhododendrons, and quite a bit of huckleberry and salal. If anything, the brush here is less dense than it was in WA. I still have the DR mower and I used it to clear the area over my septic field, but I'm a good deal older now than I was when I took on the last clearing project and I seem to get tired more quickly, go figure.
So I'm thinking of buying a small, 4 or 5 foot, rotary mower for my 42 HP CUT and using that. I know I'm going to beat the heck out of it, which is why I'm looking at the less expensive mowers. The used mowers I see advertised around here look to be pretty rough, and close enough to the price of a new one that I wonder if used is a better purchase.
So... I'd like any input on how well the King Kutter or County Line economy mowers hold up to rough use. If you know of another brand that might be better without spending a lot more, then I'd like to hear about that, too.
Thanks!
   / Any strong opinions on King Kutter Rotary Mowers? #2
I had a Howse 4' for my old 20hp tractor. I maybe had 2-3 hours on it and hit a rock. It bent the output shaft where it was 10 thousands out. I replaced the gearbox as it was really wasn't more cost effective to just replace the shaft. I sold it when I got a bigger tractor. I've hit similar stuff with a 6' Rhino (thier light duty model) I found lightly used at a dealer with no problems. So yeah I found ya get what ya pay for.
   / Any strong opinions on King Kutter Rotary Mowers? #3
The Kodiak rotaries cost only a little more but have two features that I really wanted- a sturdy tubular wheel hanger instead of flimsy flat stock, and their stays articulate so the mower can handle slope changes or backing up to a slope to mow it.
Agri-Supply carries them.
So far the only problem I have uncovered with my standard duty model is that the rear edge of the deck where it's at an angle is just folded over 90 degrees without being welded to the rest of the deck. I hung that up on a large buried rock and bent it. I bent it back and it's been fine. If it happens again I'll weld in some braces.
Their medium duty models use the same deck, just a heavier duty gearbox.
The sturdy wheel hanger is important if you back up into brush.
   / Any strong opinions on King Kutter Rotary Mowers? #4
My experience has been: Spend the extra and buy the heavy duty model of whatever brand you choose. Woods, Land Pride, Rhino etc and you will dollars ahead at the end.
   / Any strong opinions on King Kutter Rotary Mowers? #5
My brother loved his 5' pull type.
   / Any strong opinions on King Kutter Rotary Mowers? #6
I have a 5ft KK cutter but I think I would buy something different if I was to "beat the heck out of it". I think for the money the KK is a good cutter for my use and I have not had a issue with it. If you plan on "beating" one, the extra weight of a HD unit is needed. A light cutter will hop around quite a bit while a heavy one stays planted.
   / Any strong opinions on King Kutter Rotary Mowers? #7
5' light duty rotary cutter = 450 pounds
5' medium duty rotary cutter = 650 pounds $1,600
5' heavy duty rotary cutter = 1,000+ pounds $3,200
$3,200/20 acres = $160 per acre assuming unlikely "0" resale. Cheaper than hybrid corn seed.
Regardless of your brand/weight decision you make, order optional chain debris guards front and rear. Without chain guards you will soon bend "guard" sheet metal which is integral to deck and not designed to be replaced. When revolving blades hit deformed metal, the noise and bucking of the deck will get your attention. Cutter overhauls are $600 each at the dealer.
YOU BOUGHT ENOUGH TRACTOR.
BUY ENOUGH IMPLEMENT.​
   / Any strong opinions on King Kutter Rotary Mowers? #8
King Kutter cut well. The best of cutters I have owned. The 3 point frame and tail wheel are pretty flimsy and will not take much abuse.
60 Inch XTreme Duty Rotary Brush Cutter Is a nice unit for a decent price.
   / Any strong opinions on King Kutter Rotary Mowers? #9
Like others have mentioned, the KK is a light duty cutter. it'll be fine for heavy tall grass, weeds, and maybe some brush or a few saplings. But if you are going to be cutting down lots of saplings, and heavier brush, it might be a bit too light. You might be better off spending a bit more for a heavier duty cutter.
   / Any strong opinions on King Kutter Rotary Mowers? #10
I have a 5 foot King Kutter I used with a 33 HP tractor. If it was only used for meadow mowing without rocks it would be fine. I had both rocks and pretty good saplings etc. Just too light for that. Deck got beat up, blade cut into deck once etc. I would not suggest the same for what you described
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
KOHLER 24 HP ZT1 7000 SERIES (A50322)
KOHLER 24 HP ZT1...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52748)
NEW 2024 LOAD...
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
1996 CUSTOM ALUMINUM 16FT CAR TRAILER (A52141)
1996 CUSTOM...
