Any tip on changing blade for Wood RM-59?
   / Any tip on changing blade for Wood RM-59? #1
wkheathjr
Bronze Member
Seven Springs, NC
80's Massey Ferguson 240
I tried to change the blade on my RM-59 today with no luck. :confused:
I put a screwdrive through the hole to hold one of the blade while I try to loose the bolt on other blade but nearby bent my screwdrive. I called my buddy over to help me hold on to blade with his deadly grip but I was way too much for him to hold on to it.
Any suggestion or tip that I may have overlooked? I tried to look for other way to lock the driven system but no luck. I haven't changed the blade since I bought it couple of years ago so.. Instead, I grinded the blade to mow the grass for now but would like to go ahead and change the blade tomorrow before I mow field again this coming weeked so grass would look good for next event on Sept 17-19.
Thanks in advance for answering!
-Ken
   / Any tip on changing blade for Wood RM-59? #2
I think they are left handed threads. My 306 was.
   / Any tip on changing blade for Wood RM-59? #3
RM-500 is left hand thread as well, It discharged to the left hand side.
   / Any tip on changing blade for Wood RM-59? #4
Are you using a impact wrench or a regular wrench by hand ? A impact will get it loose from the hammering action. Be careful of possible turning blades at the same time.
   / Any tip on changing blade for Wood RM-59? #5
Instead of using your friends deadly grip, try placing a block of wood between the blades and the end of the mower housing to keep them from spinning while you loosen the bolt.
   / Any tip on changing blade for Wood RM-59? #6
two things - PB Blaster and an impact wrench. obviously, make sure if its a left hand thread you're going the right way. a bolt/nut set with a good impact is nearly impossible to break free w/o breaking out the torch.
ahm
I have tried using my large socket wrench because the swinging arm is 16 inches long and even used a firewood to hold the blade but haven't had any luck. I wish I could use impact driver but my air compressor is not working. I said to heck with it and grinded that old blade until it was sharp then mow. I will use blowtorch when I have time to do it in Oct. I have event coming up this weekend so time is essence for me.
-Ken
   / Any tip on changing blade for Wood RM-59? #8
I have a piece of pipe that slips over the blade and hits up against the next spindle. Woods sells a tool to hold the spindle. I use a piece of pipe on the T bar that holds socket. I don't want to get into how I know that a piece of pipe on a ratchet is a bad idea. My rm59 is threaded backwards too. It is amazing how hard it is to get those bolts loose.
Chris
2025 12V Diesel Pump, Hose And Nozzle (A50323)
2025 12V Diesel...
Toro Zero Turn (A50324)
Toro Zero Turn...
Moyno Sludge Pump (A50121)
Moyno Sludge Pump...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
40' CONTAINER (A51244)
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
