Anybody ever have a hood not close?
   / Anybody ever have a hood not close? #1
Ducati07
Bronze Member
Northern California
Kubota L45 TLB
I've got a new L45TLB and my hood won't close.
Anyone else ever experience a hood that won't close?
   / Anybody ever have a hood not close? #2
Is the "scissor" strut (not sure what it's really called) stuck or is the hood hitting something?
You mentioned in another post that you cleaned your air filter. Did you get the housing back properly?
Just guessing here. Got a pic?
I'll check the strut out but it seems to me that the hood is hitting the frame of the radiator. Under the hood there is a small bracket where the pin is that catches the latch on the tractor. The bracket on the hood is prevented from going down far enough to catch the latch on the radiator frame.
I was able to remove the springs on the hood and then slam it down as hard as I could...and the hood will latch. But I don't see any other way than to grind metal.
I think I could just grind the bracket on the hood that holds the pin...where it has been hitting so much that both the bracket on the hood and radiator frame shows signs of repeated contact. Does my description make any since?
I think the air filter is good to go because I do that daily, but I will double check.
I try posting some pics next few days of days but I'm so booked that I'm just going with it.
Thanks for the brainstorm idea of the strut and air filter!
   / Anybody ever have a hood not close? #5
Makes sense. I would think things would really have it be out of whack to have that kind of trouble.
Any visible marks under the hood to definitively identify what's the rub?
Did you say it's new? If it's that out of whack I would have the dealer rectify. I know down time is money.
1275 (A50490)
1275 (A50490)
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
