Anybody ever try using a skid steer box grader to maintain a gravel drive?
   / Anybody ever try using a skid steer box grader to maintain a gravel drive? #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
I have a gravel drive and it's getting torn up from use. Typically I'll use a bucket with a bolt on edge to smooth it out. A couple of back drags is all it takes. Lately I've been thinking of trying a land plane, but then I discovered box graders. Lots of videos showing them quickly creating the perfect surface on large flat gravel lots. Well, my drive is has a bunch of tight elevation changes. The 180 turn that cork screws up between the upper and lower levels of the barn is one tough spot. My guess is that anytime the grade is not parallel to the machine the box grader will only cut on one corner. What if the grader was mounted on a center pivot? Do they work as well as the videos show?
   / Anybody ever try using a skid steer box grader to maintain a gravel drive? #2
For many years we maintained 3-4 miles of well travelled road with a simple 'drag'.
It consisted of 2 8 ft 'legs' with 3 ea 8 ft blades.
2 blades were angled in one direction at perhaps 30 degrees with the center blade angled the opposite way and more angled (to counteract the other 'pulls')
2 passes and that gravel/dirt road was like freshly paved.
We pulled this with an old Willis Jeep and a reasonable speed as well.(like trot but not run pace)
This sort or rig can be made up with simple 3 x 3 or 4 x 4 angle stock.
If you need more aggression add weights, or again 'teeth' on the front blade.
CATERPILLAR 325FL EXCAVATOR (A51242)
CATERPILLAR 325FL...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
