QueBota
Was able to remove the four bolts ( 2 per side) that hold the YPipe to the exhaust flange ears. Wasn't easy, threads on the bolt and the ears took quite a beating removing the fasteners, lots of heat, Kroil, Freeze spray etc.
Need to create a chasing/cleaning tap from a new fastener and perhaps a chasing/cleaning die from a new nut to try to clean up the existing bolts and bores in the manifold ears.
Not sure whats left of the threads in the ears, the threads on the bolts are pretty much gone, except for where they were in the exhaust flange ears. Would have snapped of if Ford hadn't used a M 12 1.75 bolt with a 15mm head, pretty meaty fastener.
Going to try to use the removed bolts if possible, I have each one marked to the bore it came from. I think new bolts will not match up very well with what is left of the threads in the exhaust flange ears. YPipe and flanges were together since 1991.
I know you need to cut a "slot" to give the chips room so they don't gall the threads.
Any advice appreciated.
Thanks,
Q
Thanks,
Q
