Anybody Have Tips For Spraying Without Foam Markers?
   / Anybody Have Tips For Spraying Without Foam Markers? #1
Oleozz
Veteran Member
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
I have a 110 gal sprayer with 30 ft booms, was spraying Roundup today on some weedy fields and know I am overlapping with the spray. I try to watch close where I'm going but you almost need another set of eyes to watch the sprayer controls and the booms. Anybody have any good ideas so I don't get any overlap? I know they sell a dye that can be put in your tank and have thought of the foam markers but the foam system is quite expensive. Thanks for any ideas.
   / Anybody Have Tips For Spraying Without Foam Markers? #2
Perhaps a handheld gps?
   / Anybody Have Tips For Spraying Without Foam Markers? #3
There was a thread on homemade foam system - quite interesting and affordable - you might do a search for that - fellow with a NH.
   / Anybody Have Tips For Spraying Without Foam Markers? #4
Don't bother with dyeing the pesticide solution; you won't see it from the seat. We ended up buying a foam marker, 'cuz our boom is only 10 ft, and that means room for more overlap, more waste. We dyed the last tankful of solution, just so we'd know when we got it all cleared out of the sprayer on the clean-up cycles.
   / Anybody Have Tips For Spraying Without Foam Markers? #5
I'm cheap. I bough a couple of cans of cheap shaving cream and I'd just squirt a dollop every 20ft or so. Of course, my tractor is small so I could reach over the side to do it. My boom is 10ft so I just had to judge the distance but it worked well and I didn't have any green stripes after the Roundup kicked in . I wouldn't be too concerned about overlapping with Roundup, more can't hurt much. Now some selective herbicides would be a different story.
   / Anybody Have Tips For Spraying Without Foam Markers? #6
toilet paper and a can of water. wad it, dip it, throw it.
   / Anybody Have Tips For Spraying Without Foam Markers? #7
My sprayer is like yours. If I'm spraying something like Roundup (try Eraiser, it's half the cost), I just watch my tire tracks to maintain distance and come back a week later to hit any strips that I missed. I can usually use my smaller one with a boomless nozzle for the cleanup.
If I'm spraying Grazon, I'll usually use dye and follow up a few days later with the small sprayer on the back to catch any areas I might have missed and a weed wiper on the front to get stuff like Johnson Grass that the Grazon doesn't kill.
I've used a friends rig with foam marker and it's nice but I never thought the cost of the generator and foam solution was worth the investment. If I was spraying real large fields, I'd probably feel different. A lot depends on how often you do it and how big the fields are.
   / Anybody Have Tips For Spraying Without Foam Markers? #8
If you're only spraying roundup what is the problem with overlapping ?
I have seen a lot of farmers spraying crops used to drag a car tyre on the end of the boom so the damaged foliage gives you something to aim for .
Damage is minimal and recovers fine ?
The problem with the overlap is I'm wasting a lot of spray. Even the generic brand is not real cheap, don't know about you but I don't have a lot of money to spare so want to make the spray go as far as possible.
   / Anybody Have Tips For Spraying Without Foam Markers? #10
Where do you live ....Roundup is the cheapest i can remember it right now glyphosates are only about $3 an acre , **** some chemicals cost us $40 an acre ....Spread that over 2000 acres ,If a little over-lap was a big cost issue i would be the first to complain , We use tram-lines now but even so we are still overlapping about 2 feet on either side ,I've had custom rogators with GPS do worse than that and you pay these guys to do it .Theres electronic substitute for a "DRIVER".
Vatco Holding Cabinet (A45336)
Vatco Holding...
Trailer Axle (A47809)
2020 Deere 26G (A46443)
2020 Deere 26G...
New Holland 256 Hay Rake (A47809)
New Holland 256...
John Deere 4WD 6x4 Gator (A47809)
John Deere 4WD 6x4...
Adams 5-Ton Ground-Driven Fertilizer Spreader  Reliable & Field-Ready (A46884)
Adams 5-Ton...
