anybody use one of these ?
   / anybody use one of these ? #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Rear Mount Mower or Brush Hog to mow out over ditches and banks.
How well does it work?
How much weight do I need on the front of a BX1500 to keep the rear mounted implement from tipping the tractor over backwards?
   / anybody use one of these ? #2
You mean like this?
Mowers
Unfortunately the minimum horsepower is 40...
   / anybody use one of these ? #3
   / anybody use one of these ? #4
I have done it but didn't feel very comfortable with it. As you back up, make sure you raise the mower just to the point where the rear wheel comes off the ground. If you don't do this, the mower will drop and your blades will dig into the ground.
   / anybody use one of these ? #5
Brush up on your welding and fabrication skills and build one. There have been several homemade ones built on this forum, and Steiner makes one for their lawn tractors/mowers if you need a pattern, however they are a little more horsepower than your little tractor. I think my Steiner is 23.5 horsepower and more recent models went to about 28 for the same diesel engine equiped model.(mines a 525)
You are only limited by your imagination and motivation.
David from jax
David from jax
I've got some different ideas on that which I havent seen anyone else try..
   / anybody use one of these ? #7
There may be a reason...:D:rolleyes:
   / anybody use one of these ? #9
LBrown59 said:
An I think there was a reason we didn't have cars before Henry Ford and Airplanes before the Wright Brothers.:p
Because there was no LBrown59? just a guess ;)
2020 CASE SV280B SKID STEER (A52709)
2020 CASE SV280B...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
TROY BILT GAS POWERED POWER WASHER (A58374)
TROY BILT GAS...
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
Great Dane Van Trailer 1989 (A56436)
Great Dane Van...
