Anybody uses a Fasse ISO Remote Master Hydraulic Doubler Valve Kit 700-1510
   / Anybody uses a Fasse ISO Remote Master Hydraulic Doubler Valve Kit 700-1510 #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Anybody know anything about this style valve? Brother is contemplating upgrading to a small payloader and I thought this would be a good choice for adding a grabfork circuit. I am hydraulicly challenged so wise and experienced opinions would be greatly appreciated. Thanks.
Fasse Remote Master Hydraulic Doubler Valves feature a durable aluminum valve block capable of up to 20 gallons per minute flow rate.
Fasse Remote Master Features
The simple plug-in design of the Fasse Hydraulic Valves feature and easy connection for operation.
Multiplies Existing Hydraulic Outlets
Controls 2 circuits from your lever
Works on all ISO Hydraulic Systems
Easily transferable to multiple units
Saves money over factory add-ons
12 Volt switchbox control mounts in cab
No high pressure hydraulic lines or cables in the cab
Valve will flow up to 20 GPM
System Includes: 12 Volt switchbox, wiring harness, (2) male tips with eccentric fittings, 4 female couplers, (2) control solenoids, valve block
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
71055 (A49346)
71055 (A49346)
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
