Anyone drive T-posts with FEL?
   / Anyone drive T-posts with FEL? #1
C4Ranch
Veteran Member
Eastland Co, Texas
Kubota L5240 HSTC
Title says it all. Need to lay down close to 200 yds of new barbwire and wondering the quickest process with what I already have and little cost.
   / Anyone drive T-posts with FEL? #2
Easy to bend with a loader. A piece of pipe about 24" with one end capped and handles on the side works good.
   / Anyone drive T-posts with FEL? #3
i bent too many when i tried.
   / Anyone drive T-posts with FEL? #4
Yes, I have driven t post with my fel. if your ground is not to hard or rockey, push a little at a time. If you try to go to far to fast, it may bend or not go in strait. it takes 2 peopel to get it strated on to hold the post the other to work the loader
   / Anyone drive T-posts with FEL? #5
They do it all the time here. Just have to have someone to make sure it's straight when you start and push it in and let off and move the tractor a tad if it's springs out of position. They use the channel on the bottom of the bale spear to push them in with. I wouldn't try with the bottom of a bucket unless you're good enough with a loader that you can keep a bucket level as you're pushing in.
   / Anyone drive T-posts with FEL? #6
I have to agree they are easy to bend in hard ground, if you hit a rock or even a root. But if all goes well it does save time and a back ache.
   / Anyone drive T-posts with FEL? #7
A rotary hammer drill works best. I made an adapter to fit over the post and in the hammer drill. It drives them in fast with little effort.
   / Anyone drive T-posts with FEL? #8
My wife and I have used our FEL to install 200 or so. We have clay with some rocks. I have bent a few over the years, but not too many. Our Bobcat worked well. The loader was fast enough that you could smack them a little, instead of just pushing. After starting she would move well out of the way.
You do need to use care.
Bill
   / Anyone drive T-posts with FEL? #9
It works better when the ground has some moisture in it. Around here the ground gets mighty hard in July and August. We've done many. Go slow and make sure your helper moves back.
   / Anyone drive T-posts with FEL? #10
Put a dozen or so in with the FEL recently. I was by myself and noticed some missing or knocked over. I got them started a bit by just muscle and when they would stand by themselves, I would get on the tractor and finish the job. I didn't bend any, but did push a few deeper than I wanted...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
