Anyone have experience with a "drop axle" tractor?
   / Anyone have experience with a "drop axle" tractor? #1
andrewj
Platinum Member
South Carolina
JD 5105
Anyone have experience with a \"drop axle\" tractor?
for high-crop work? Just want info on the reliability of a drop axle or drop wheel.
   / Anyone have experience with a "drop axle" tractor? #2
Re: Anyone have experience with a \"drop axle\" tractor?
Lot's of hi-crop tractors built. Not sure what the question is, but I suspect if they were built by a major tractor company, they would stand up to the work put up to them.
For awhile, I had a hi-crop Deere, but didn't like being that hi up so went to the utility model which, if I remember right, moved the wheel axle aft rather than down. Much the same castings I believe. Not much ground clearance but a tough tractor and stuck to the hillsides real well.
   / Anyone have experience with a "drop axle" tractor? #3
There are a lot of them around here, but not in private use. Mostly they are owned and used by outfits that sell and apply various sprays to crops already up and growing. Timken had one that had a lift under the belly to haul rolls and/or bars of steel around within the plant, like a rolling "overhead" crane. They seem fairly reliable, or at least they are in use quite a bit at certain times.
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2015 DODGE RAM...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
Kubota U55-4 (A50120)
