Anyone know how to reduce noise level on a JD 5055?
   / Anyone know how to reduce noise level on a JD 5055? #1
logix
Midland ,Texas
John Deere 5055E Case 2090 JD 620 Farmall F20
I have a JD 5055 E and was wondering if anyone knows how to make these quieter. I think this is loudest tractor I have ever driven that has all of the muffler in place.
   / Anyone know how to reduce noise level on a JD 5055? #2
Does it have any kind to roof mounted on roll bar. Did not see one in any picture I just reviewed.
If you came from a less than 50 HP class that could be a factor.
India imports a good tractor in most all cases but seem to be less refined like with noise.
Sounds like a super tractor.
Welcome to the Forum.
   / Anyone know how to reduce noise level on a JD 5055? #3
You could try a good set of on the ear noise headphones. The decibel level of most tractors isn't good for one's hearing and this is a cheap fix.
   / Anyone know how to reduce noise level on a JD 5055? #4
Does it have a canopy on it?
It does have a canopy with the noise reducing material underneath. I wear earmuffs all the time and add earplugs if plowing for extended time. Its much louder than my tractor twice this size.
   / Anyone know how to reduce noise level on a JD 5055? #6
Then I would say it's as quiet as the factory intended. You could call them and ask about a different muffler or other suggestions.
   / Anyone know how to reduce noise level on a JD 5055? #7
About the only way to reduce the noise is to put on a good cab. This quiets them down quite a bit but you are never going to have it run quiet like setting inside of a car.
   / Anyone know how to reduce noise level on a JD 5055? #8
FIL or BIL removed the roof off of the ROPS to make the 1976 265 MF more quite to ride right after they got it. I leave it off due to low limbs when bush hogging.
   / Anyone know how to reduce noise level on a JD 5055? #9
Do you have the vertical riser pipe? Ask dealer about a side exhaust kit that turns down. Maybe this would reduce the noise. Personally I was surprised on how quiet the 5075E is, even with the pipe located on the side close to the operator station, as compared to the 6 cylinder 4020's and 4230's I grew up on. I guess it's all relative. In fact, I was worried when I cut about 10" off the pipe and put a flapper on it so it would fit in the shed that it would be louder, but I don't notice it.
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
