Are All LED Lights Heavy in weight??
   / Are All LED Lights Heavy in weight?? #1
Tractor Tom
New Brunswick, Canada
Kioti CK35 H
I've been looking for LED lights to replace the factory lights on my CH35 with factory cab. The 4 inch square or round LED's I've looked at seem a bit on the heavy side, compared to Halogen lights?? The Factory Cab light mount is only thin fiberglass, I'm afraid over time the vibration and a heavy light will crack and break the fiberglass mount. What are you guys using for LED's on your factory cabs?? Thanks
   / Are All LED Lights Heavy in weight?? #2
The weight is ballast to keep the LED cool. I don't think you will find a good quality LED that isn't a bit on the heavy side.
The fiberglass should be strong enough to support a light easily. Even very thin fiberglass is very strong. Just keep the bolts tight as abrasion from vibration can wear thru fiberglass pretty fast.
   / Are All LED Lights Heavy in weight?? #3
Fender washers to spread the load, custom backing plates, many ways to avoid point loads on glass.
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
