Are these vents and should you be able to blow air through them?
   / Are these vents and should you be able to blow air through them? #1
Bigmuddyriver
New Holland TC35D
Was doing some maintenance on my bush hog decided to see if these were clear. I have two gearboxes on this machine. I removed them and couldn’t blow through them. Shouldn’t they be open to keep pressure from building up in the gearbox and blowing out the seals. Reason I ask I just recently had to replace a seal in the other gearbox.
   / Are these vents and should you be able to blow air through them? #2
They are vents but usually not exactly "free air". The gearbox and oil slowly heat and cool and it doesn't surprise me that you can't blow through them with your mouth.
Think of it more as a filter.
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
John Deere 250 Skidloader (RUNS) (A50774)
John Deere 250...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52748)
Neckover GL24-2-7K...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
Kohler 50 Generator (A50774)
Kohler 50...
