attachment needed for drainage trenches
   / attachment needed for drainage trenches #1
n219ct
Essex, MA
JD 4320
Hello,
I am looking for an attachment for my JD 4320 (48HP machine). I need to clean out and make drainage trenches in my fields.
I am considering a V-shaped rear plow. Does anyone have any experience with these or other methods of cleaning out shallow drainage trenches?
Thanks in advance,
John
   / attachment needed for drainage trenches #2
n219ct said:
Hello,
Thanks in advance,
John
hey John,
I have seen a BOX blade with the right angles made used for this.. and a scrape blade do the same...
check this out..
http://www.tractorbynet.com/forums/owning-operating/116316-various-boxblade-uses.html
Let me know what you come up with. I might be able to make it work to clean out my ditches if you come up with something new...
later,
Jim
   / attachment needed for drainage trenches #3
How about a 1 bottom plow pulled both directions so the dirt is tosses away from the center. You would get a 12-14" trench pretty quick. Then a back blade / rake to pull the dirt away from the edge and spread it out.
jb
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
12in x 16.5in Kubota RTV-X1140 Tires (A52377)
12in x 16.5in...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
