Sprayer ATV sprayers
   / ATV sprayers #1
HRS
Georgia
I'm thinking of adding a sprayer to my arsenal and have looked at both tractor driven and atv driven units. Since I don't have huge areas that may need spraying with roundup, etc, the tractor units might be a little much. I'm thinking of 1/2 to 1 acre projects. With that being said, both the TSC and others, such as Southern States, sale ATV sprayers. I'm thinking about a boomless sprayer unit, 25 gallon, that is capable of administering spray from the rear or a wand. If you have tried such a unit, how do you like it?
   / ATV sprayers #2
HRS,
that is exactly the way I went. Welded a three point frame for a 25 gal sprayer and I have used a seperate battery too. It handles everything I needed. I spray two gardens and all my fruit trees and around my 4 acre pasture fence. Works for me great, and the size seems perfect.
Not too expensive either.
Y&B
   / ATV sprayers
Yellowandbeige
Thanks for your input. I've got a raincheck on one from TSC, and wanted to hear from someone before they get it in. Making a 3pt frame for it was really smart. For a small operation, you certainly saved yourself several hundred.
   / ATV sprayers #4
I'll start by saying that I'm in the process of making a PTO driven sprayer and as of yet have no past experience with one. My understanding is that you can have a constant 60 psi or higher range with the PTO pumps which relates to more constant coverage on a boom and much farther spray delivery on a hand wand.
That said I have used a couple of 12 volt driven sprayers and was not impressed with either. They cycle off at 60 psi when you let go of the hand wand but aren't capable of good steady working pressures as they are being used.
If your not looking for good steady adjustable pressures then you might get by just fine with an electric model.
   / ATV sprayers #5
I needed a sprayer mainly for chemical edging (Roundup), something more than a pump-up, but didn't want to go overboard. I found an ATV style sprayer, 15 gallon, on sale at Harbor Freight. It fits perfectly in a small trailer I have for my garden tractor and makes the job a breeze. I bungee it in place with a spare battery when in use and just put it on a shelf in the barn when its not needed.
/Todd
   / ATV sprayers #6
I just bought the 15 gal. unit on sale at TSC for $65 I think. It serves my basic needs for weed maintenance. I use it on my ATV. It does not have the volume I would really like to have, it is not possible to get a good wide spray. The pump cycles on and off even with spray wand spraying as much out as possible.
James
   / ATV sprayers #7
I bought the 16 gallon unit from TSC. It has a short "boom" with only 2 spray heads. Covers maybe a 6' wide path. But for my acre around the house it works great for something like broadleaf weed killer. And fits easily on the back of my Honda Rancher. I also use the wand for spraying fence rows and such at the "farm".
   / ATV sprayers #8
I borrowed my B-I-L's "Fimco" 40 gal ATV trailer mount last weekend to put out 160 gals of "Remedy" on the (*&*(^#@&^&^ serecea. It has a 60" fold out boom with 5 nozzles. It worked terrific, but it was a little difficult maintaining an even speed (4 mph) to get the right spray rate, particularly over the really rough parts of the pasture. We also rode along the roads and could easily hit 10-12 feet back with a good coarse spray. We used one driver and one rider with the spray wand for this. All things considered, if I borrow it again, I'll either mount it to or pull it with the tractor.
   / ATV sprayers
Good points guys. Fimco is the sprayer I'm considering, sounds as though it should do just fine. I did look at and liked the sprayer with the fold out boom also. However, TSC had only the tank. The boom to go with it must have taken a walk. The boys there couldn't find it. Maybe they shouldn't store them right inside the double doors. Seems like they are kind of popular.
   / ATV sprayers #10
Since I already had a little carry-all to use on the tractor, I got an ATV 15 gal. elec. model from N.H. Northern, on sale for $89. I lay a short 2 x 12 on the carry all, lay the sprayer on that, and bungee strap it in place. I have been very satisfied.
Having no frame of its own, the lightweight tank is easily stored on a high shelf in the garage and the carry-all is useful for numerous other things. I put tiny casters on the bottom of it and it rolls right under the brush hog (which is on a dolly) for storage in garage.
   / ATV sprayers
The sprayer came in on Wednesday, and I was able to pick it up today, Fimco LG3025. After I play with it tomorrow, I'll tell everyone what I think of it.
   / ATV sprayers
OK, I put the sprayer together today and tried her out. My initial impression is a good one. I think it will serve my needs. Again, it is made by Fimco, purchased at TSC. The tank holds 25 gallons and it is equipped with both a gun and three nozzle "boomless" boom that is capable of spraying a 30 ft path.
The gun is activated if you pull the trigger. There exist a lock out device on the trigger to keep it/you from accidentally spraying it when not needed. Other than that, the gun is always ready to go.
The pump quickly pressurizes the lines to about 42 PSI. There is a pressure release valve attached that is connected to a short hose which redirects released liquid back into the tank. This is how you adjust the pressure on the gun. Let's say you want only 20psi instead of 40. You slightly open the pressure release, thus bleeding off the extra pressure faster than the pump is capable of building it. This is a Simple design that seems to work quite effectively.
Someone said that maintaining a constant flow rate with these ATV tanks was difficult. With this unit, you simply open the pressure release slightly as you engage the gun. This causes the pump to run continuously, which overcomes a pulsating effect you will experience if the gun is used at full pressure. For example, at full pressure, the pump stops, but it starts as soon as the gun is used. The pump is fast and able to rebuild full pressure while gun is being used. It rebuilds full pressure and then shuts off again, only to start up again, only to shut off, only to restart, only to shut off, only to restart, and you get this funky pulse to the spray pattern. Well, slightly bleeding off a little of the pressure causes the pump to run continuously and deliver a smooth spray pattern. Additionally, the required bleed is very slight, so you really don't loose force coming out of the gun. Toying with the bleed valve is not needed when running the rear spray nozzles.
The rear spray nozzles are mounted on a short 3ft boom. The one in the center sprays down and covers something like 6 ft. The nozzles on either end spray down and out. They cover the 15 ft or so to each side. Each nozzle can be turned off, so you may run only the center if you like. The end nozzles pivot up or down. Each click in the pivot cycle equals 15 degrees. The instructions tell you to run the end nozzles at one click up or 15 degrees above horizontal to achieve the advertized spray pattern. Well, I toyed with this and decided that I like to set them at horizontal or even 15 degrees down. Actually, I think that 15 degrees down offers the best spray pattern. Sure you loose some of the fan effect, but even at 15 degrees below horizontal (or one click down) the nozzles deliver a 16 plus foot spray pattern. This pattern is very concentrated and strong also. I felt that elevating the nozzles in a slightly elevated position created a course dropplet pattern on either end. Maybe this would work, but I've found that grass requires a "good" spraying of roundup to kill it. So, I will probably opt for the 16 ft pattern when clearing areas for my seed beds.
Hope to actually put it to work next week.
   / ATV sprayers #13
HRS do you have some concrete that you can spray with clear water and then post a picture of the coverage of the boom-less nozzle?
Is your regulator and pump capable of producing a continuous 60 PSI or better?
   / ATV sprayers
Pine, On this unit I'd guess that it only builds to 40 psi. The only thing mentioned in the manual about adjusting pressure is as follows...
*When the bypass valve is closed, pressure is at the highest point.
* Opening the valve will decrease pressure.
So when closing the valve, the pressure gage reads a little over 40psi. This seems to be plenty of pressure though. The gun shots a strong stream quite a few feet, and the booms nozzles are able to deliver that 30 ft spray pattern. So, the pump/pressure seems just fine for what it is advertised for. I can't wait to put it in the field.
As far as the concrete test, I'll see what I can do.
3720, Thanks. I have looked at these for some time myself. Actually, the only frustrating part to it was trying to mount it to my ATV. I was not able to use some of the bracets provided, just did not fit my ATV rack, but that did not matter. It also has two designated areas to attach ratchet straps, so I was able to overcome that problem in about 2 minutes. Also, I clamped the boom brackets to my bumber instead of the rear rack. A snap to take on and off like this. But each will modify as he sees fit.
   / ATV sprayers #16
I bought the same sprayer. After mounting it and after only spraying about 5 to 8 gallons, the motor quit. The pump started smoking and started melting the wires. I got the China version pump. I went to TSC and they exchanged it with a FloJet pump. It looked more durable than the yellow headed China pump. Well, they have changed the sprayers from when they used the FloJet pump that was used on the older versions. The FloJet pumps in the opposite direction and the pump mounts on the opposite side of the tank. So, I am now waiting on another China pump to arrive at TSC for me to exchange for the proper pump. I hope that the next China pump is better. If they aren't, I will "Southern Engineer" a way to put a Flo Jet or Surflo pump on after my warranty expires.
   / ATV sprayers
Well, I ran 20 gallons through it while playing with it. Sure, there are plenty of pumps one could put on the tank after warranty. Such pumps are used in just about all RV's with onboard fresh water tanks. So, finding a replacement should not be a problem.
   / ATV sprayers #18
Here's a little tidbit regarding adjusting pressure that's not in the manual:
On the end of the pump, opposite the switch, there is a little square plastic cover. Inside that cover is a screw - the screw controls the adjustment of what pressure the pump will shutoff at.
I have a similar FIMCO ATV sprayer - but it's the one with the 7 nozzle fanspray boom - uses the 45psi, 3.8 gpm pump ...... same as yours I think. I think mine currently runs around 50 or 60 psi.
I found out the above from tech support at Fimco when I was having problems (bad check valve) with my original pump. They were kind enough to send me out a complete new pump (rather than just the check valve.)
   / ATV sprayers #19
That's great customer service, can't ask for more than that.
   / ATV sprayers
rswyan,
Thanks for the info. I've seen the cap you are making reference to. I'll give it a look. Yes, it seems the pump is the same on the two units you mentioned, actually has "45psi pump" printed on the label.
Might some of the problems experienced with such pumps come from the trash that finds its way into the tank when it is being assembled? I took the time to run my hand around the inside of the tank and pull out the fine plastic shavings from tank being drilled, etc. Sure, the intake hose has a filtering screen on the end of it, but these shavings were nice and fine. I would image that they could cause a good deal of damage if they enter the pumps impeller.
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
KBH Tank Trailer (A56438)
KBH Tank Trailer...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
