Auger Control
   / Auger Control #1
Pa Pa Jack
Hodges, SC
Mahindra 3016
I bought a post hole digger from Everything Attachments. I love it. It has saved me so much work it is unreal. I have one question for those of you with a lot more experience. Is there a "control" leg that could be added that would stop the auger a a very controllable depth? Something like a depth stop. I have heard the term used but can find no reference to online.
Thanks,
Jack
   / Auger Control #2
On my Kubota I have an adjustable stop on lever to operate 3ph so if you raise mower can lower it to same position or height is this something you have on your machine I have also seen where the auger is painted different colors a different depths I know paint will wear off but last for a while
   / Auger Control
Thanks. I have an adjustment on my Mahindra also but it doesn't always work properly. If the auger grabs a rock or a larger root, it will suck the auger right to the max. I plant a lot of trees and shrubs. I want something I can set so that it will only go 12 or maybe 16 inches deep and I can just keep moving down the line. I have a lot of clay about 15 inches deep. If I hit that clay, it will almost suck the tractor into the hole.:)
   / Auger Control #4
I see your point an auger is just a big screw so if its turning and bites it going to screw itself in ground. I know on line trucks with auger it's controlled by lowering boom but you don't have this option where I live not a rock problem so I didn't even think about it but I'm sure some of these people have experienced this and will come up with solution.
   / Auger Control #5
I don't know of a stop but the only thing I have used to remove a stuck auger is a 4 ft pipe wrench.
   / Auger Control
I have had to do that twice. Both times the auger got stuck an a very large root.
   / Auger Control #7
Why? :confused: Your 3pt hitch has position control, if you use it, it will stop the hitch from lowering. Don't just push the 3pt control lever all the way forward.
   / Auger Control #8
I agree with this...bump the lever forward so it digs a little, wait, bump, remove huge rock, repeat. The only time I got in trouble was when I got a little too confident and my bumps on the 3pt lever got bigger and bigger. Ended up having to remove the auger manually.
I also remove the auger totally about halfway down to pull all the stick clay out that sticks to the auger, seems to help a lot in not getting it stuck.
Also, I operate the PHD at idle or just above, going much faster makes the shaking and vibrating and digging speed too much
Joe
   / Auger Control #9
Joe
Best to clear the auger every 12"-16". Doing this prevents problems from occurring. I go down 16", raise 12", down 16" raise 24", down 16" and am then done. Stop the auger and pull out loaded with dirt.
Idle seems to work best for me. I just don't see why people use it any other way, but they do. :confused3:
Just my :2cents:
   / Auger Control
Well, maybe your control works better than mine. Once the auger gets a bite, it will pull the bit right to the bottom unless I run the rpms very low. Then it will stall the tractor. I have a stop on my depth control. I set the stop and see how deep it will go. then I'll adjust the stop a little more. It makes no difference. when the rpms are high enough to dig well in this hard ground, if the bit gets a bite she's going to the max depth.
Now I realize and understand that I am new at this. I have never had a post hole digger before. I want to learn, but so far I have been unable to get control no matter what I have tried.
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2022 NORSTAR (A52472)
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
