Auto Throttle not working in lawn mower
   / Auto Throttle not working in lawn mower #1
amorey
Kubota BX24
I have a Poulin mower with a B&S Series 550 engine. It has not adjustment screwed on the carb, just a spring.
It idles fine, until it gets hot after 1 minute then revs up and down, looses power and can't mow.
Is there a way to adjust the low and high throttle settings?
   / Auto Throttle not working in lawn mower #2
Thorough cleaning of the carb is in order.
First run of the year? Did you put stabilizer in the fuel last year?
Such a cheap mower either going to put a manual throttle on it, works fine when controlled by hand, or just get rid of it, was $110 new.
   / Auto Throttle not working in lawn mower #4
Have a similar one w/ the same issue , it would only throttle up if you would manually push the governor lever. My buddy cleaned the carb & it works better , no great but better good enough for a cheap old mower
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Eagle Weathervane (A55853)
Eagle Weathervane...
Forklift (A59228)
Forklift (A59228)
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
