Auxilary power feed on l3240
   / Auxilary power feed on l3240 #1
slan
Nova Scotia, Canada
Kubota L3240 HST
I want to power some work lights on the rops and want to pull some power from that area instead of running all the way back to the fuse block (or to the battery via a relay this winter)
I thought the 3240 was supposed to have an auxiliary power outlet under the seat in the form of a cigarette lighter but all I have is a plastic slug where it could be installed.
There are three connectors under the seat that are empty. Is one of these auxiliary power and if so which one, what capacity, and is it switched or constant.
Thanks in advance....:D
   / Auxilary power feed on l3240 #2
I have the same question. Looks like three plugs under the seat with yellow and black wires terminating in a blue connector. All three plugs look the same. Does anyone know if these are for the factory work light or were the work light connector is on a Grand L 40? One thing I noticed is the fuse block only has a 10amp fuse for work lights so I may need to run a dedicated power cable anyway.
   / Auxilary power feed on l3240 #3
On my GL3130 there are some plugs under the seat to lock the tractor into first gear in case the Glide Shift controler fails. It involves putting the connectors together and it applies power to the proper solenoids. Not sure what function they do on the HST though. If you need power to run many lights you need to go to battery or fuse block as those auxillary circuits cannot handle that much power. The work light plug under the fender (think it is under left side and is bullet connector) is good for one(1) lamp as that is all it is fused for and what Kubota supplies in the kit.
David Kb7uns
1265 (A50490)
1265 (A50490)
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
