AKRazn
Hi there,
I have been reading this site for about a year now, trying to gain all the knowledge I can about compact tractors and have learned A LOT, so thank you everyone for your contributions. I am in the process of purchasing my first compact tractor for my remote property here in Alaska. I have 5 acres of HEAVILY wooded land right on the ocean and am looking for a tractor to help me clear the land as well as other building projects, i.e. water lines, burying power cables, erecting structures, firewood and eventually general grounds maintenance. In addition I will be using it to do snow removal around my office building and home here in Alaska.
I have read (and agree) that one should get the next largest tractor over the one they think will do the job. My problem is that my land is ONLY accessible by boat so the tractor has to fit on the front of one of my landing crafts. These size constraints have led me to look at either the B2650, B3350 or one of the L's (not Grand L). I see that the lifting capabilities of the 26 and 33 are the same as well as GPM flow on the hydraulics, being that I am at sea level is the extra $ of the 33 worth it? Why? or would going to the L be better?
If looking at the L's I know they cost more but they can lift more as well, seems justifiable? Also I was told by a dealer that the L's do not have mid PTO? I don't plan to add a mid mower for a few years but eventually that would be a nice feature, what other options would be out there that would make the L a good decision?
I would also like to get a brush hog at some point, I have seen videos online where the brush hog is attached to the front of the tractor? is this possible with the skidsteer attachment style front end of the 2650 and 3350? or is it possible on the L as well? or is it really worth it and a pull behind easier? What kinds of Brush Hogs would you recommend? What kinds will work with the 50 series or the L series?
Being that my main intention of the tractor is for land clearing of 100+ year old Sitka Spruce, alder and devils club / scrub brush I am interested in a grapple brush bucket as well. I do own and regularly use a log arch that I tow behind my ATV so I am thinking the tractor would be able to handle larger logs with the arch than the ATV and not sure if the grapple bucket would be of use? My thought being I can buck up the logs with chainsaw and haul them with the log arch, or is the grapple bucket the way to go?
When building and pricing out the various models on the website there are a few options I am not sure of what they are / what they do?
1. 3rd position loader valve? I assume that is to be able to use grapple buckets etc?
2. Lift Rod Kit?
3. Telescopic Lower Link Kit?
4. Hydraulic Angulation kit on loader? does this allow various attachments to pivot from left to right?
5. Wheel spacer kit? I assume this is just as the name implies but is it needed / worth it?
6. What size bucket for excavator? 12" seems to be a bit small but 24" seems to be big? I have no idea on this one. We have at most 12-24" deep top soil, then we get into the shale rock etc. so digging water lines and burying power cables etc. is what I plan to do with the excavator as well as dig up roots on the tree stumps etc.
7. Snow blower? how big will the 50 series handle is it worth it to go up to the L? I have read that the 50 series has more creature comforts? I do not plan to purchase the cab as I am worried about branches etc. and fogging of windows in our wet climate.
I have also read that either the 50 series or the L have an independent PTO? not sure what / if / how that is useful?
Tires, I have read that many go with the R4 tires (this was also suggested by the dealer) but we get a lot of rain and have a lot of moss on the ground on my property and I have read that the R1 tires do better? the property is mostly flat (maybe 100' at most of elevation change gradually sloping back from beach).
What is everyone's thoughts on the extended warranties?
I know this is a TON of questions but I thought this seems to be the best place to get first hand knowledge instead of a salesman's advice. Thank you in advance for any and all replies!
2. Lift Rod Kit?
