B-7800 hydraulics
   / B-7800 hydraulics #1
BlacknTan
Platinum Member
Adirondacks of NY
Kubota B-7800
I've finally put together everything to install the rear remotes on my B-7800. All I need are fittings and hoses.
Now for the questions..
What type fittings are on the Loader valve (LA402)? (JIC??)
What size are they? Everything appears to be plumbed with 3/8 hose...
The fitting at the tank appears to be different from the rest. The return line goes to the side of the tank. I believe that the thread in the tank is a NPT thread?? But, the 90 degree fitting appears larger than that on the loader valve and the hydraulic block.
Also need a fitting to Tee in my second return to tank line.
Finally, what size Snap-Tite QD fittings are on the loader valve??
Does anyone have a list of fittings for doing this job??
   / B-7800 hydraulics #2
The Husco valve on my LA 853 loader has -8 O-ring boss outlets and inlets. The pump, tank, and power beyond are fitted with adapters to -8 JIC male flare. The 3/8 hoses then have adapters: -8 JIC female swivel for the loader valve and -6 for the 3/8 hose.
The work ports have adapters for -8 O-ring boss to 3/8 NPT (male). The 3/8 quick disconnects are 3/8 NPT (female) and are screwed to the 3/8 NPT male on the valve. The hoses to the loader cylinders have 3/8 NPT (male) ends to attach to the other ends of the quick disconnects.
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
UNUSED INDUSTRIAS AMERICA EASY MAN TREE & POST (A60432)
UNUSED INDUSTRIAS...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A60429)
2018 JOHN DEERE...
FUTURE 6' CLIP-ON FORK EXTENSIONS (A60432)
FUTURE 6' CLIP-ON...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
Forklift (A56857)
Forklift (A56857)
