B&S 16 hp Twin 2 (magneto?)
   / B&S 16 hp Twin 2 (magneto?) #1
ruscomredneck
Ontario,Canada
Ford 2000
I have a rider with a 16 hp Briggs(model 402707,type 1212). It appears to be running only on one cylinder.I put in new plugs.If I disconnect the plug wires & remove one at a time while the engine is running one side will make the engine stall, the other side has no effect.The side with no effect has spark at the wire.Is there a way of testing the magneto to isolate the problem before throwing a bunch of parts into it.Any other tests I should be trying? Thanks in advance for any advice!!
   / B&S 16 hp Twin 2 (magneto?) #2
I had a B&S 16 hp twin with the same problem..found there was nada compression in that one cylinder.after taking off the head I found the valve seats musta came loose and wobbled around so much that they were useless. Check compression, Both sides should be almost the same, It's a simple job to remove the head.but not worth the machining to repair the seats. Let us Know! /forums/images/graemlins/frown.gif
Thanks for the vital tip! Probably would have been scratching my head for quite a while before I got in there.Do I require a new head to repair this? I'll check this out & let you know what I find. Thanks again for your quick reply!!
   / B&S 16 hp Twin 2 (magneto?) #4
Lets hope that it's not bad valve seats..unfortunatley it's also not a over head valve system. if the seats are bad enough you either need some expensive block machining or a new block let us know..
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2022 Bobcat T66 R - Series Skid Steer (A51573)
2022 Bobcat T66 R...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2012 AMERITRAIL, INC. 30 T/A GOOSENECK TRAILER (A52472)
2012 AMERITRAIL...
