B&S Vanguard twin #303447 16 hp Engine
   / B&S Vanguard twin #303447 16 hp Engine #1
sos1
Bronze Member
I need help with ignition switch. The engine has a red wire (alternator)that is not wired into the 5 prong wire plug.
There is a 6th prong on the switch. I connected it there but no luck. The engine cranks but won't start.
There is no spark. Help!!!!
   / B&S Vanguard twin #303447 16 hp Engine #2
Years ago I rebuild my Dad's B&S twin in his Gilson tractor. As I remember that installation (the manual went with the tractor when sold), the ignition switch is a part of the tractor and not the engine. That wire might just be a ground wire. Best I can say without photos. I put electronic ignition on the B&S and did away with a lot of spark issues.
hugs<<><>>Brandi
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A50854)
VERMEER VACTRON...
Heavy-Duty 3-Point Bale Spike - Efficient Hay Handling for Tractors (A51039)
Heavy-Duty 3-Point...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2024 MERCEDES-BENZ SPRINTER 3500XD BOX TRUCK (A51222)
2024 MERCEDES-BENZ...
