3-Point Hitch B21 Tiller
   / B21 Tiller #1
Leozepolusa
Austin, TX
Kubota B21 & L47 TLB
I am contemplating buying a King Kutter II 48 or 60 inch gear driven tiller. KK recommends a 20HP pto. My B21 only has 13.5 HP. Anyone have experience turning one of these with a B21? The 60" is just $30 more than the 48".
Thanks,
   / B21 Tiller #2
I think the 48" would be plenty for 13.5 hp available. I suspect you will be disappointed if you get the 60" and expect it to till at full depth. We run a 40" behind a 10 hp tractor with gearing that allows 0.5 mph at WOT and it has all it can do to till at 4" deep in anything but very light soil. Is you BX a HST or gear drive? This may become a big factor if you need to travel very slowly at rated engine speed to till.
   / B21 Tiller
its a B21 TLB rather than a BX. It has very robust power for everything else, but the PTO is weak comparatively speaking. It uses a HST with 3 speed ranges.
   / B21 Tiller #4
I have been using a KK 48" with my B21 for the last 9 years. It works well but can push the power limits on virgin ground. I don't think I would switch to 60" unless I was only working an established garden bed with good soil.
MarkV
   / B21 Tiller #5
I have a 66 inch First Choice. I use it behind a tractor with 40 PTO HP. Engine RPM's really fall off when lowered all the way down in vrigin soil. Good luck on getting a 60 inch to till with 13.5 PTO HP in any type soil, loose, established garden or virgin. In my opinion you will have a problem with a 48 inch with 13.5 PTO HP. Tillers are some what like a Rotary Cutter or Bush Hog, they like 5 HP per foot of width this is why KK recommends 20 PTO HP for the 48 inch.
   / B21 Tiller #6
I have a 5' tiller on a B2710, which is rated 20hp PTO. It has plenty of power, I don't notice it dragging down the engine even in virgin clay. But I think cutting the horsepower by a third would be pushing it. Of course, once you get it started, you can adjust your speed down but I think I would pay attention to the manufacturer's ratings.
Did you check your Kubota owner's manual? It recommends a maximum of 42" for a tiller for the B21.
Make sure if you buy a tiller that it can be adjusted sideways to cover your one tire track.
Ken
   / B21 Tiller #7
I have Bobcat CT 120 hst and Turf tires 14 pto hp with a 60 inch KK tiller (sandy loam/sod soil) . In my soil type and hst it works fine but a little slow. If (the 60 inch tiller) does not work quite fast enough for you take off some of the tines/teeth until it does. I think a 60 inch tiller may have better resale value down the road?:thumbsup:
   / B21 Tiller #8
I use a 50" on my B7100 which has 16hp and I think rated for 13hp on the PTO. In soft pre-tilled ground where the tiller can really get deep it is right on the edge of pulling the engine down. I don't think it would handle a 60" very well.
   / B21 Tiller #9
Correction on my earlier post. I walked by my tiller this morning and realized it was a 48", not a 60" on my B2710 (20 hp PTO). I certainly would not go to a 60" on a 13 hp tractor.
As for the suggestion to remove some tines, then you would be skipping areas. Best to just stick with something appropriately sized.
Ken
   / B21 Tiller #10
Our B1750 has about the same low HP. We use an offset KUHN 40"? tiller and have no problem at all tilling in our heavy but rock-less soil. My dealer warned me against to large a tiller and I'm glad I listened.
I suppose you could get by with a 60" if you use a plow first or it was an established garden.
Another thing to consider...whatever you get plan on doing your friends/neighbors lot too.
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2015 FREIGHTLINER (A50323)
2015 FREIGHTLINER...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
1.5 Rolls of Red Brand Barb Wire (A50515)
1.5 Rolls of Red...
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
