B219 Replacement Lift Cylinders?
   / B219 Replacement Lift Cylinders? #1
Lil Foot
Kubota B7100DT
Does anyone know of an exact drop in replacement for the lift cylinders on a B219 FEL?
As I am crazy overloaded with things to do these days, a swap would be far more time efficient than a rebuild of the old ones.
I don't have the tractor with me right now, but I will pull a cylinder next time I'm there for the exact specs.
Just hoping someone has been that route already and has the correct cylinders identified.
Thanks in advance.
   / B219 Replacement Lift Cylinders? #2
Are they both leaking?
One is leaking to the outside, both are bypassing. (no lift power or down pressure)
Curl cylinders are normal.
Cylinders have been rebuilt 3 times that I know of.
   / B219 Replacement Lift Cylinders? #4
Remove both cylinders. Take them to a local hydraulic shop for rebuild or replacement.
Thanks.
Gravely Tractor (A50325)
Gravely Tractor...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
