B2400 Hydro Fluid Leak
   / B2400 Hydro Fluid Leak #1
Behrend II
Bronze Member
Menomonie, WI
LS XG3140H
Hi,
My B2400 just started leaking hydro fluid at a pretty rapid rate. It streaming out about exactly dead center under the tractor but I can't see where it's coming from. I haven't had time to look to closely and thought someone could point me in the right direction before I get started. It's coming out as a steady stream and forms a decent sized puddle in a few minutes. Any thoughts? Thanks.
Tom
   / B2400 Hydro Fluid Leak #2
The problem that I have had is the Hydro leak is comming from the steering column there are two lines you have to remove the gauge cluster you can see them my guess is the line closest to the engine compartment
Thanks, I just have to get in there and look around.
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Landoll Lowboy Trailer (A53473)
Landoll Lowboy...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
