Howard92
Bronze Member
When I was installing the sub-frame for my new BH65 back hoe, I noticed that the hydraulic filter (filter on the right side) was bent up pretty badly. Apparently I had done this bush hogging some rough mtn land we own. I had chopped off a lot of locust, sassafras and buckthorn trees with a machete. I left them about 2' tall, which turned out to be the perfect dimension to get pushed down by the front axle and then pop back up and hit the hydraulic filter rather violently.
Anyway, I need to change that filter. The owners manual talks about draining all the fluid before removing the filter. When I changed the HST filter at 50 hrs, I had read about using a shop vac to keep the fluid in whit the filter removed. Seems like I drove it up on some boards to get the tractor tilted away from the filter and that worked fine (as I recall). My question is, can I do the same thing when changing the hydraulic filter to keep the fluid from running out?
Thanks for any help,
Howard
Howard
