B2920: cruise control mechanism causing HST pedal to stick in neutral sometimes
   / B2920: cruise control mechanism causing HST pedal to stick in neutral sometimes #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
I have been noticing this off and on annoyance over the last couple weeks, where the HST pedal occasionally won't go into forward or reverse unless I really stomp it. I lubed everything really well at the 50 hr service, but no change. Today it happened so I shut the tractor off, crawled underneath, and determined that the pawl on the HST pedal bar was stuck in a slot on the cruise control mechanism. (Side note: this suggests that purposely engaging cruise while the pedal is in neutral would probably be an effective anti-theft trick).
I am not sure if it's vibrating into that position, or is happening as part of setting the parking brake, or maybe both. Now that I think of it, every occurence has probably happened *after* the tractor was idling in place with the brake set for a while while I did some work off the seat. I did notice that the brake mechanism is tied into the cruise control mechanism somehow, but haven't studied it yet.
I'm wondering if anyone else has experienced this, and found a fix. There's enough friction in the cruise control mechanism that I don't think the lever could vibrate down on its own, so I am suspecting that there is some interaction when I set the brake.
So it looks like the mechanism connecting the brake pedal to the cruise linkage was the culprit. Every time I pressed and released the brakes, it would slowly walk the cruise stop out little by little until it engaged the HST pedal in neutral. I greased the mechanism, and it took care of the problem.
I assume the mechanism connects brake and cruise so that cruise is disengaged when using the brake pedal.
2015 Mack GU813 Truck, VIN # 1M2AX13C0FM028499 (A44391)
2015 Mack GU813...
2019 Chevrolet Tahoe SUV (A44572)
2019 Chevrolet...
INOP/NON-RUNNING 2007 Kenworth T800 Truck, VIN # 1NKDX0EX87J172444 (A44391)
INOP/NON-RUNNING...
2009 FORD F-750 TANDEM AXLE 24FT BOX TRUCK (A43004)
2009 FORD F-750...
PENDING SELLER CONFIRMATIONS ON SOME LOT #'S (A43003)
PENDING SELLER...
Fleco 6T 50mm Main Pin Hydraulic Thumb (A42203)
Fleco 6T 50mm Main...
