b6000 3PH
   / b6000 3PH #1
cappys tractor
Bronze Member
Cape Cod, Ma
B6000 4WD
Hope someone out there has seen this.
My b6000 has a hyd valve controlled by the rear 3PH lever. It works fine when the valve is closed all the way. The FEL works great. No hissing, or hyd overload sounds.
However, when opening the valve (to shut off the FEL), to make the Rear 3PH work nothing happens. The FEL does not work (as it should) and when pushing the lever to "lift" it makes the usual hissing sounds of 'overloaded' hydraulics.
When I bought it the guy said the rear 3PH 'used to work, some time ago' but didn't even recall how to make the valve work. I took the valve apart, and 'inspected it. looks fine. And now upon fully opening the valve it makes the 'overloaded' bypass sound.
Any thoughts? has anyone had the 3PH apart? looking at the parts list and schematic it is hard to decipher how the 3PH works (the up and down part)
I have not been able to get a shop repair manual for this. the shop manual from SSB is actually an operators manual, labeled shop manual. (that sort of disappointed me!) Any one got experience with one of these?
Any suggestions where to look? I may have to resort to taking the old dinosaur to the kubota dealer.
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
Brown TCO-2625 6 ft. Tree Cutter (A50860)
Brown TCO-2625 6...
2018 JLG 1644 4x4 15,000lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2021 Spartan RZ Zero Turn Mower (A50860)
2021 Spartan RZ...
2006 International 4400 LP Ambulance (A50323)
2006 International...
