B6200 wont lift 3 point
   / B6200 wont lift 3 point #1
BruceWard
Platinum Member
Central, AR
My Uncle has a B6200 that will not lift a rock rake attached to the 3 point. It will not lift very high even with nothing attached. It is not leaking fluid. It is old, dirty and abused. Any ideas where to start looking?
   / B6200 wont lift 3 point #2
What pressure is your hydraulic system running at? You'll probably need to know this to start with and then work from there.
   / B6200 wont lift 3 point #3
the piston on my old b6000 ate the o ring. it cost a total of 15 bucks (including shipping) to get new ones from kubota dealer. and about 30 mintes to dissassemble and reassemble. like new.
do you have the parts manual?
the piston is directly under the seat, usually unbolt 4 or 6 bolts to remove the cover. wiggle, and lift the piston out, replace 2 orings and reassemble.
although your 6200 is a newer generatin than my old dinosaur, i am sure it is similar. a parts manual would help decipher where to take apart.
   / B6200 wont lift 3 point #4
You may want to even start with just looking at the linkages to see if they are all connected or bent/stripped or something. This tractor should have position control on the 3pt. I have a service manual for this model if you have some specific questions.
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
7021 (A50322)
7021 (A50322)
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
