B7001 alternator
   / B7001 alternator #1
Simon Westmacott
My B7001 (similar to B7100) has a permanemt magnet alternator rated at 8 amps but only works if the engine revs close to max. As I have an electric water pump (and thermostat) drawing 1.2 amp in place of thermosyphon cooling which didn't work, the problem is exacerbated and I resort to a mains charger after almost every outting. I've changed the regulator unit which improved the output but it's not enough. Anyone got a solution, such as a proper small alternator, say 15 amp, which could be rigged up instead? The engine is in superb condition so hopefully will last a long time yet.
   / B7001 alternator #2
The Hitachi alternator for a 1980's Nissan/Datsun pickup is a perfect replacement... it is self regulating... (has an internal regulator).
It is small & will put out over 30 amps... simple wiring hook up.
This replacement has been used on a lot of tractors... KennyV
BTW you can getr them from most auto supply stores, rebuilt for less than $50 .... PART IS: Hitachi 14231.
   / B7001 alternator #3
I know you didn't ask, but the cooling should work without a pump if the radiator is clear of chaff and not mineral-ed up inside.
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
John Deere 7000 12 R 30 Planter (A50514)
John Deere 7000 12...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
UNUSED AGT MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED AGT MINI...
