B7100 Cooling Question
   / B7100 Cooling Question #1
Erik Graham
Bronze Member
Toronto, Ontario
Kubota B2630,Ford NAA, Kubota L2550GST
Greetings;
My 7100 has an overheating problem. I have read through the archives and have made sure the rad is clear of all debris and that the rad is full. The little "whistle" device doesn't actually whistle but it does have a bit of steam and hot water coming out of it. Engine oil level is fine. There is nothing escaping from the rad cap, but the engine smells very hot after a fairly short run time.I'm not entirely sure how the siphon system works. Is there a thermostat or some other device in the water circulation system? Somewhat puzzling.
Cheers, Erik
   / B7100 Cooling Question #2
How good shape the fan belt??? worn/loose??...have you flush the rad.
   / B7100 Cooling Question #3
I have the same tractor. While reading through the archives I came across "Must be 50/50 antifreeze and water!" more than once. Did the problem just start? Did you do any work on the tractor just prior? Like add/change radiator fluid?
Charles
   / B7100 Cooling Question #4
This wouldn't happen to be a thermosyphon system would it?
Soundguy
Greetings;
Thanks for the replies. I have only had the tractor a copy of weeks and haven't got a lot of seat time in as yet, so I don't really know if this is a recurring or a new problem.
Hadn't thought of the 50/50 mix. The first time it got hot I let it cool down and added a quart of straight water, in hindsight that probably wasn't the best choice.
Fan belt looks to be in good shape and and seems to be adjusted correctly.
The only other thing I can think of is that rad might have a build of micro crud. Unfortunately the was the FEL is mounted there is a component that gets in the way of removing the exterior screen. I shone a flash light in there but couldn't see anything obvious but looking at a few other maintenance issues it wouldn't suprise me if it hadn't been blown out since the day the loader was installed.
Lastly, yup it's a thermosuction system. I was wondering whether there is a thermostat somewhere in the system that opens and closes as engine temps flucuate.
Will try the coolant fix first and take another peek at the rad.
Cheers, Erik
   / B7100 Cooling Question #7
I would remove the exterior screen and check the rad for crud between the cooling fins. Lift the hood and shine a light from the fan side and you should be able to see if it is clear or not. Mine was full of stuff when I bought it. It gets dirty pretty fast if you are working in dusty conditions. Mike
   / B7100 Cooling Question #8
Changing the coolant is a quick one. Be sure to look inside the radiator for crud, might need a flush. It's a bit of a pain as the hood doesn't open that far.
When I replaced my lower radiator hose heater (for cold weather starts) it took right at a gallon of antifreeze to refill. I bought the 50/50 premix... costs a little more but manual says to mix the antifreeze and water together before you fill the system anyway. Using premix made the whole process easier.
   / B7100 Cooling Question #9
Many of the yanmars have thermosyphon systems. In areas where we can get away with it.. we only run 70/30 water/AF.. in cold areas.. we run what we have to for freeze protection. The lower % helps the water circulate better.
soundguy
   / B7100 Cooling Question #10
The radiator could have a lot of crud in it that you can't see. I would wait till it cools off completely and then use a hose with a nozzle on it and wash the heck out of the radiator, spraying it from both the front and rear. Wash it long enough to dissolve any layers of dirt that may have built up.
I would also drain the radiator and replace with 50/50 water/anti-freeze. I never trust the last person who owned a piece of equipment no matter how they say they maintained it.
I am assuming you have changed oil/filter and trans fluid/filter.
Bill Tolle
3ft Teakwood Indian (A57454)
3ft Teakwood...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
