B7100 ROP's
   / B7100 ROP's #1
furnacebrook
Vermont
1979 Kubota B7100
B7100 ROP\'s
I hope someone may direct me in the right choice here. I have a 1979 B7100 gear drive without ROP's. I did not give it much thought until almost rolling over a few times this year. Now it seems like a very good idea to put them on..........the sooner the better. Well, I contacted my dealer and their out of stock at the moment for awhile. The cost would be about $325.00 with shipping. I found a used one for almost the same amount. seems a bit pricey for a used one. Does anyone know of one that's more reasonable? I thought of welding up one on my own but, it would probably take more time than I have to spare. One other thing, the used dealer was estimating it to be around 200lbs for shipping cost. That sounds high also.
Thanks for any help out there.
Scott
   / B7100 ROP's #2
Re: B7100 ROP\'s
I just purchased a ROPs system about six months ago for my B7100. At that time Kubota offered a Half off certificate.I cannot find it on there web site now.I guess they stopped the promotion. 300.00 is the going price on the ROPs. I suggest contacting Kubota to see if they still are running that promotion!
   / B7100 ROP's #3
Re: B7100 ROP\'s
Upon further review, If you go to the Kubota site under safety and ROPs buyers guide you will see that the ROPS system for a B7100 is still sold for $ 148.00. The actual weight is close to 200 lbs. It can be installed easily with minimal mechanical ability and that could save you a chunk of change. it will take 2 people to install. I hope this helps!
   / B7100 ROP's #5
Re: B7100 ROP\'s
Actually, if you have a chain hoist or some other way to suspend the ROPS at the right height, it can be done by one person. I installed the ROPS on my late seventies B6100 myself.
You'll also need a jack stand for the Tractor since you have to remove one of the rear wheels ('least I did on the B6100).
   / B7100 ROP's
Re: B7100 ROP\'s
Thanks for all the help boy's. I checked that link and I'm heading for the dealer today to see what they have to say about it. They might not have known there was a discount when they gave me the original price.
Just curious, WVbill, why did the rear tire need to be taken off. Not entirely sure how this thing is mounted on the tractor. I've seen pictures that seem to indicate it sits on or replaces the PTO cover. I have all the necessary tools for the job, no problem there( my wife thinks I have too many tools but, as we all know there in no such thing as too many tools!!!). I'm still debating on welding up my own but if the cost is only $148.00 plus shipping it's not worth the effort.
Thanks again for all the help
Scott
   / B7100 ROP's #7
Re: B7100 ROP\'s
Please keep us posted on what you find. I'm curious if they honor the price and what shipping will cost. Maybe I can benefit from your work... /forums/images/graemlins/grin.gif
   / B7100 ROP's #8
Re: B7100 ROP\'s
Yes, the ROPS replaces the PTO cover - but it also extends down and has a hole that engages the shaft for the 3PH lower links. You need to remove the shaft, set the ROPS in place and re-insert the shaft thru the ROPS bracket and the original housing. That shaft is about 14" long as I recall and there's not 14" of clearance between either wheel and the 3PH housing so the wheel needs to come off to allow the shaft to be R&R'd.
The ROPS comes with very good instructions with pictures so no worries there.
   / B7100 ROP's
Re: B7100 ROP\'s
Not yet, still waiting for the dealer to let me know. I'll keep you posted.
Thanks,
Scott
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
44500 (A51692)
44500 (A51692)
2008 Saturn VUE SUV (A50324)
2008 Saturn VUE...
