B7200HST Hydraulic pump seal leak
   / B7200HST Hydraulic pump seal leak #1
St-Albert, On
Kubota Bx 24 tlb
Hi guys, my father bought a b7200 hst last fall, he likes the tractor but problems are poping out. First his high low range was shifting to low only. I took the trany appart to find out someone had forced the shift (high low) lever and had bent the shift fork. I had the job done in 4 hours by taking the top cover off insted of splitting it, heated the fork with torches and bent it back. The trany shifts fine now,but He has a hydraulic problem. The oil got dumpted in the crankcase. I replaced the front seal on the pump and it ran fine for about 5 hrs then the same happened! I was told not to waist my time and install a new one.
I need some advice, should I replace the pump, install a complete seal kit or just the front seal again. I forgot to mention that the imput shaft has scoring where the seal rides.
Does some one know where I can find rebuilt pumps at a good price?
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
