B7300 3pt lift height?
   / B7300 3pt lift height? #1
bikerdib
Platinum Member
Texas
Kubota L4701
I need help from some of you Kubota Gurus.
I am not the original owner of my B7300 so I have no baseline to go by. How do I adjust the maximum upper lift stop of the 3 point lift arms? I'm not talking about where the set screws are, I'm asking; how do I know where to set the stop so I don't strain the pump or lift arms or anything else?
No one?
OK, maybe I confused everyone with the way I asked the original question. I'm thinking the original owner set the stop for upward lift of the 3 pt at less than maximum lift. However, before I move the stop I want to know how I can tell what the maximum lift of the 3 pt is. Will I hear the pump strain as it reaches maximum lift? Is there some type of stop built in so nothing will be damaged? I just want to get some input before I experiment. Anyone with a shop manual that can answer this question?
   / B7300 3pt lift height? #3
I am not sure about the adjustment, but just like a front FEL or other hydraulic attachment the engine will load up at the travel limit and the relief valve will open. I know there is a procedure for adjusting the upper limit, but without a shop manual in hand I would be hesitant to try. The manual for the L2800/3400 series states that if the lift unit is improperly adjusted, the hydraulic unit can be damaged. I believe it is refering to the upper limit set to high to where the relief valve is opened and the cylinder is under constant max pressure.
   / B7300 3pt lift height? #4
I have not seen that warning in my L3700SU manual, but wasn't looking for it of course.
The only adjustment I have come across so far for the 3pt was a video by Orange Tractor about making sure the two arms are level to each other to provide a level lift. It did not indicate anything about upper limits to the arm positions, so I don't even know if it is possible to set them wrong in that respect. :(
SNIP...I know there is a procedure for adjusting the upper limit, but without a shop manual in hand I would be hesitant to try. The manual for the L2800/3400 series states that if the lift unit is improperly adjusted, the hydraulic unit can be damaged. I believe it is refering to the upper limit set to high to where the relief valve is opened and the cylinder is under constant max pressure.
That's what I want to try and avoid doing.
On the B7300 there is a nut that can be set to limit the lift height just like the settable stop for a lowering limit. There is less room for adjustment on lifting height as opposed to lowering limit however. The reason I'm asking for this information; on my tractor the nut setting the lift height appears to be set to limit the raise height to the very least. When I use my shredder that is not a problem. But I recently put my blade on and I want to cross a ditch and cut the banks down to make a low water crossing. I could use more lift height if it is possible. I'm thinking about backing the nut off, raising the 3pt till I start hearing a strain, backing off from there a little then setting the stop nut so I never reach that point again. I'm just concerned that I might still be straining something by doing it this way.
Electric Parts Movers (A50121)
Electric Parts...
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
Army Semi Trailer (A50774)
Army Semi Trailer...
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
