B7610 tire question
   / B7610 tire question #1
tmthunder
Bronze Member
The Great North Maine Woods
Kioti NX4510CH
I currently have turf tires on my 7610. I am looking at getting some AGs. The manual says to use 11.2-16 on the rear. I have access to a set of 12.4-16's on rims. Will these work or are they to tall? Same size front tires 7-12 as the manual calls for. I think the 12.4-16's are on the 7800, 2910, ect..
Also I washed her the other day and today while using it I noticed a squeak coming from the rear axle. After a search here I am thinking that I have to grease the hex shaft. Does this make sense to you guys?
Thanks!
   / B7610 tire question #2
I am not sure about using the 12.4-16s on the rear, as you mentioned. However, be sure that you use the correct Front/Rear tire combination. The gearing in your differentials and drive train is balanced to a particular Front/Rear tire size combination. If you have a mismatch you will have all kinds of problems when running in 4 wheel drive. The front will want to go faster than the rear or vice versa.
Jim in NH
Thanks Jim I think that I will end up going with the 11.2-16 which is about a 35.5" tire and where the 12.4-16 is about 37.5". The two inches would throw off the ratio because both combinations use the same front tire size 7-12.
   / B7610 tire question #4
Did you say you washed your tractor? WHY? :D:confused:
I would start with greasing the hex shaft, as that is most likely the issue with the squeak.. Its an easy and cheap starting point in trouble shooting... Good luck...
2013 Infiniti JX35 SUV (A50324)
2013 Infiniti JX35...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
377811 (A48836)
377811 (A48836)
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
