B7800 fluids
   / B7800 fluids #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi,
Going to do a total fluid change.
Can someone just reply and tell me what kind of fluids I should use?
130 hrs on the tractor, uncertain if the 50 or 100 hr service was done. Hope so, but the fuel filter has some stuff in it so I'm not so sure.
engine oil type and filter
trans fluid type and filters
front axle type
anything else?
Dont have manuals yet. thanks again, bret w
   / B7800 fluids #2
Your hydro system uses 2 filters:
Kubota parts numbers 66021-36060 and 67955-37710
The engine oil filter is Kubota part number 16271-32092
You can use Kubota UDT fluid in the hydro, but I would use Super UDT, which is what the tractor comes filled with. You can also use Super UDT in the front axle (or 80W-90 gear lube)
As for engine oil, 10W-30 or 10W-40 with an API Service rating of CF.
The fuel filter is Kubota number 6A320-59930
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2011 Mack CXU613 Truck (A52128)
2011 Mack CXU613...
UNUSED MOWERKING QUICK ATTACH BOX BROOM (A51244)
UNUSED MOWERKING...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
