B7800 O-ring replacement on hydraulic tube to trans.
   / B7800 O-ring replacement on hydraulic tube to trans. #1
TranceAcresKubota
Kubota B7800
I have a 2007 Kubota B7800. The tube that carries hydraulic fluid between filter housing and trans. is leaking. A diagram I found shows the tube having 2 o-rings on each end. Hoping to find someone who has changed these out before and can give me some guidance on replacing these o-rings. Thanks.
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2015 DODGE RAM...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
