B7800 will not run after rain?
   / B7800 will not run after rain? #1
Old Kubota
B7800
Had a lot of rain the other day now my B7800 will only run for about 30 sec then shut off and will not start again until it sits for a little while.
Right before it dies black smoke comes out, i put in fresh 5 gallons of fuel it's doing the same thing.
The Water Separator at least that is what it looks like is not clear anymore so you can't see inside it. Could it simply be that? I haven't tried to empty it whoever put it on last used a pipe wrench. lol
I need to buy a new one.
   / B7800 will not run after rain? #2
Another possibility is that the air filer got wet and isn't allowing enough air into the engine.
   / B7800 will not run after rain? #3
When I got my b7800 from the neighbor after sitting for 6 years outside, we put fresh diesel in the tank and it started right up ran for a few minutes and turned off. we disconnected the fuel line to the filter and let it just drain for a while and the water in the tank just drained out and has never acted up since 2 years now. just a thought. drain it at the fuel filter and drain and clean the fuel filter.
I checked the air filter it had a nest in it, drained the Water Separator and it will not start.
It turns over just no start. It ran fine the last time i used it before it rained.
   / B7800 will not run after rain? #5
Most likely when you emptied the fuel/water separator, you introduced air into the system and now it will probably need bleeding before it will run. Hopefully your starter and battery are in good shape, as bleeding a system is never easy on them.
David from jax
   / B7800 will not run after rain? #6
David from jax
My understanding is the lift pump is manual and runs off gear in engine. When mine had water after draining water I did use starting fluid(not saying to do that) if not comfortable with that you will need to open your injector lines and crank till air is removed from lines and tighten and hopefully start.
   / B7800 will not run after rain? #7
You could be very much correct, however... if the lift pump runs off the gear in the engine, then it requires a good starter and battery to get it to turn over if the engine won't run.
Don't run the starter for long periods, as they get hot very quickly and take a long time to cool off. Patience, patience and then more patience when trying to bleed a diesel system!
David from jax
David from jax
How do you bleed it?
   / B7800 will not run after rain? #9
When I blead the injectors on Diesels on my old Ford tractor and my Dodge diesel 24 valve that I have now. I open all the nuts on the injectors and crank it over and while I'm cranking if I see fluid fuel coming out of the injector I close it down and I continue doing that without over running the starter until they're all flowing fluid. then I would in this case make sure that the glow plugs are firing up and the tractor should start up. It is possible it will start when you have the majority of the injectors, then tighten the remaining injectors and it will run ruff and straighten out
   / B7800 will not run after rain? #10
I hada B7800 and bleeding the system was very easy. Look in the owner's manual for instructions because I don't remember. Don't start fooling with lines till you try the easy things.
One big thought is that you must have more than a half tank of fuel in order for the system to bleed on it's own.I forget the details so check the owner's manual.
EDIT---Something else I know is that the fuel lever you turn when you drain the water filter has to be turned to do the job. It WILL turn 360 degrees and you turn it 180 degrees ONE WAY to close the fuel. When you turn it back, you must reverse the turn you made and not continue around. You can, in error, turn it it full circle back to where you think it started from but it will partially restrict fuel and not run for more than a minute after starting. The answer is to turn that lever back. Maybe you did this?
Now, it's been a while so I may not remember all the turn degrees correctly but know to just turn the lever one way to close and fuel and turn it back the way it came to open things up. I mad this mistake and spent a while trying to figure it out. Don't fool with lines and stuff because Kubotas are made to bleed lines on their own and bigger problems can be created. Kubotas are almost foolproof.
2004 Ford E-350 Super Duty Cargo Van (A48081)
2004 Ford E-350...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2018 John Deere S780 Combine (A50657)
2018 John Deere...
Cyclone 4826 Sand Blast Cabinet (A50860)
Cyclone 4826 Sand...
2009 IC Corporation PB105 School Bus (A48081)
2009 IC...
