Nov 18, 2003 / Back-up Warning Beeper #1 H HarleyBob Silver Member Joined Jan 23, 2001 Messages 163 Location Puget Sound, WA. What would I need to do to add a back up alarm to my L3010? One that I could disable when I did not need, and one I could use when I am around people.
Nov 18, 2003 / Back-up Warning Beeper #2 Gatorboy Elite Member Joined Aug 5, 2001 Messages 3,138 Location Bel Air, MD Tractor Kubota M8950, Bobcat 873 SSL & Kubota ZD-331 To disable the beeper, you just need to unscrew and remove the power wires to the beeper. The first thing I did when I got my Bobcat was disconnect that annoying BEEP BEEP BEEP.
Nov 18, 2003 / Back-up Warning Beeper #3 Egon Epic Contributor Joined Aug 14, 2001 Messages 22,507 Location Nova Scotia, Canada If it's hst a simple pedal activated switch like the one on the clutch pedal should work. Tie this in line with an on/off switch and you should be in business. Don't forget a fuse. Egon
