backhoe bucket tooth
   / backhoe bucket tooth #1
gilbertson
Suffolk, VA
Satoh
I lost a tooth off my backhoe bucket, it is the kind that you beat in on the sides. Does anyone know where I could find a supplier?
Vern
   / backhoe bucket tooth #2
I believe what you are referring to is called a 'peen on' style. Do you need just the tooth and the shank is OK? I have seen the tooth/shank sets on Ebay but finding just the tooth would be a little harder. Likely need to try a dealer for whatever manufacture of hoe you have.
   / backhoe bucket tooth #3
If you have a Bob Cat dealer in the area check with them. At least here they stock a pretty good assortment.
MarkV
   / backhoe bucket tooth #4
Call the local general engineering/ heavy civil/hwy/ pipeline contractors in your area. They'll know of suppliers that deal primarily with cutting edges, teeth, shanks, etc. Dealers will put a decent markup on these items.
Thanks, I will check out the bob cat dealer
   / backhoe bucket tooth #6
I get mine for my little JD hoe from my JD dealer, under $10 each. I have to heat them a bit in order to peen them. Sometimes I even tack them with some 6013.....
2015 TEXAS PRIDE  GOOSENECK (A52472)
2015 TEXAS PRIDE...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
2015 KENWORTH T880 MID-ROOF SLEEPER (A52472)
2015 KENWORTH T880...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
