backhoe bushings and hardened pin from ?
   / backhoe bushings and hardened pin from ? #1
john_bud
Super Member
Hi,
Where is a good (cheap) place to buy new pins and bushing for use in a backhoe?
Thanks,
john_bud
   / backhoe bushings and hardened pin from ? #2
JB, I called ford about the bushings in my ford 555B and they had them 121.00 + tx. I wint to General transmission, a local bearing/belt/shaft supplier and they made them for me in a couple hrs, 68.00 tx included. You might want to check with a machine shop in your area
   / backhoe bushings and hardened pin from ? #3
Try to find a hydraulic scrap yard it your area...........Cylinder rods make great hardened pins.
   / backhoe bushings and hardened pin from ? #4
On cylinder rods used for pins, remember cylinder rods are generally 10/45 steel, not hardened but the chrome plating is what gives cylinder rods their longevity. The steel *can* be hardened, if you've got a big enough torch. I built a backhoe attachment years ago and made my own hardened pins and bushings. I picked up an old kiln, about 3ft in diameter that someone had thrown out and made up the pins and bushings on a lathe. Then case hardened them using a product that MSC company sells, I believe it is called Kasenit (?) I can't be sure of the spelling, it's been 20 yrs.. It worked great. I know the dealer prices are an absolute rip off.
UNUSED 20PCS 1.2 in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 1.2...
Segway i2 Personal Transporter (A48082)
Segway i2 Personal...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
2005 International TranStar 8600 Hydro Vac Truck (A50860)
2005 International...
UNUSED 120 Pairs Safety Work Gloves (A50860)
UNUSED 120 Pairs...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
