Backhoe Backhoe for the 4110 Help!
   / Backhoe for the 4110 Help! #1
raa
Hi,
I have been looking for a backhoe to use on my 4110. What I unsderstood from Mahindra that the 4110 uses the bradco 509 or 511. The probelm is you have to get the Bradco via mahindra. Dealer prices for the 509 in over $9500. I was able to find few used Bradcos 509 or 511 in excellent shape for far, far less than $9.5k. My questions are: Can you use the standard bradco 509/11 on this tractor without any problems? Also, if a subframe is required, can some get the subframe only and mout a standard 509/11 on it. I just cannot see spending nealry $10K on a backhoe for this tractor.
Any help will be greately appreciated!
Thanks!
RAA
   / Backhoe for the 4110 Help! #2
You would need to special order the following: Tractor half sub frame kit, backhoe half sub frame kit, plus the hydraulic kit or the PTO pump/tank kit. The rest of the backhoe is probably the same. The $9500 is list, you can buy it for quite a bit less normally. If you are on the west coast, contact me.
   / Backhoe for the 4110 Help! #3
I also understand that Mahindra will not allow any 511's on the 4110 model tractor anymore... I had the first if not one of the first 511's on a 4110. I had no problems other than having to get a PTO pump to run the hoe,. The original 4110's didn't have much hydraulic power,. I believe it was 7 gpm. A 511 needs 11 gpm to operate properly, at a minimum... The other problem I believe, is the 511 can very easily over power the 4110 tractor. If you are not efficient, and have many hours running a hoe,, one can easily do serious damage to a 4110 series tractor.,.. On mine, I could have allowed the 511 to "whip" the tractor around like a child's toy... I can fully understand Mahindra's concern in mounting too big a hoe for that sized tractor. I heard the 9 footer is largest one can get now....
   / Backhoe for the 4110 Help! #4
What state are you from?
   / Backhoe for the 4110 Help! #5
My specs show a 4110 to be 4000# naked, with an 8gpm hyd
pump. The weight is the issue and I agree that a b/h the size
of a Bradco 511 is too big. A 509 would be ok with subframe,
of course. I do not know the cylinder diameters on the 509, but
based on the specs, it looks like no more than 3". 5-6 gpm is
plenty of flow for this cylinder size.
Thanks for the reply. Unfortunately, I am in North Carolina. I have never had good luck with the Mahindra dealers here. Just curious, what would be a fair price for the 509.
Thanks!
North Carolina - Near Charlotte
   / Backhoe for the 4110 Help! #8
I have a 3375 mahindra backhoe with a 4110 frame mount that I would make you a great deal on. I sold my 4110 last year & I dont need this one any more. It was a demo with less than 3 hours on itErnie
Can you email with the specs on the backhoe and whether the kit is specifc to it.
randari@msn.com
Thanks!
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
IH 445 Square Baler (A50515)
IH 445 Square...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
