KJM
I'm hoping someone has had this problem and fixed it!
Problem: Tried to use the BH this morning. No hydraulic power
. Pump spins fine on the PTO, plenty of oil in the tank, no input restrictions. Disconnected the pump pressure feed from the valve stack - plenty of oil at high velocity! The outward symptom looks to me (I'm not a hydraulics guru) like there is a blockage in the valve stack or the pressure relief valve is almost 100% bypassing. There is a tiny bit of very jerky hydraulic power getting there, enough to slowly shudder the stabiliser rams up an inch and down an inch but nothing near enough to make the main boom or dipper stick even think about moving
I have taken the top of the relief valve assembly off but there is no obvious chunk of grot stopping it closing. If I rev the engine I can feel the hydraulic lines "pulsating" somewhat - makes me think it really is the relief valve. I have never seen a stack of spools disassembled, but clearly there must be pressure galleries that line up, exhaust ports that line up etc etc. I'd rather not try to take the thing to bits on a Saturday and am hoping there is a simple technique for dealing with this!
Any suggestions? I'm thinking I need to "reverse flow" the valve stack to flush whatever entrained crud is in there out - but I don't know if there is some kind of one-way mechanism in there. H E L P!!
/Kevin
/Kevin
