Backhoe Backhoe Info
   / Backhoe Info #1
nitewowl
Keller, Texas
JD4600
Just found a JD4600 with a Kelley B750 on it with 3 point attachment. Does anyone have any info on how well this works or if there are any issues to consider before I move forward??? Thanks.
   / Backhoe Info #3
I'm not really familiar with the model, but I don't like 3pt hitch backhoes under any circumstances on a CUT. Subframe BHs are much better/less stressful on the tractor. I know a lot of people use them without incident, but it won't be me. John
   / Backhoe Info #4
niteowl, sorry I don't have any info for you, but I agree with the others that a 3pt hitch is not the way to go as far as keeping yourself safe. I got a woods backhoe off of E-Bay that came with as 3pt hitch and ended buying the sub frame for safety reasons alone. I have a B1700 and purchased the subframe about a year ago. 2 months ago I got a call that Woods has a recall on the sub frames for not being strong enough. The dealer contacted me, came out to inspect it and took care of everything. Luckily I had the already modified sub frame and didn't have to deal with anything. I don't know if it's only for those sub frames that attach to my particular model tractor or not?? But for others out there you should look into it....
   / Backhoe Info #5
</font><font color="blue" class="small">( niteowl, sorry I don't have any info for you, but I agree with the others that a 3pt hitch is not the way to go as far as keeping yourself safe. I got a woods backhoe off of E-Bay that came with as 3pt hitch and ended buying the sub frame for safety reasons alone. I have a B1700 and purchased the subframe about a year ago. 2 months ago I got a call that Woods has a recall on the sub frames for not being strong enough. The dealer contacted me, came out to inspect it and took care of everything. Luckily I had the already modified sub frame and didn't have to deal with anything. I don't know if it's only for those sub frames that attach to my particular model tractor or not?? But for others out there you should look into it.... )</font>
Sounds like a good reason to stay away from back hoes on the BX 2230 and the MF 2300.
1268 (A50490)
1268 (A50490)
CATERPILLAR 336FL EXCAVATOR (A51242)
CATERPILLAR 336FL...
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
