Backhoe leak at starter
   / Backhoe leak at starter #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
83 JD 500C backhoe.
I put a new starter on a few months ago. Now when running, it leaks frothy oil in a steady stream where the starter is mated to the engine housing. Is there supposed to be a gasket there? I don't remember one on the old starter which was the original from '83. Seems like the 3 bolts that hold it on place a torqued pretty tight.
   / Backhoe leak at starter #2
Could be rear main leak.........
No idea since I'm not much of a heavy equipment mechanic. Starter is right on the side & easy to see & it looks like frothy oil is oozing right where the starter attaches. Only leaks when engine is running. Guess I'll pull the starter back off & take a look. Must have missed something installing it.
I don't know what an enginebreather is.
Decided to watch it happen as the machine was started and found it is coming from the top of the starter - looks like it's the housing that covers the bendix and holds the solenoid? Appears to be coming from this area:
This is a [very crappy] video of it right after startup. https://youtu.be/mFJkpKFjAEY
   / Backhoe leak at starter #6
alot of this equipment was built that the starter drive ran in oil there possibly is a gasket missing also might try to follow flow see where it starts
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
Gleaner R50 Combine (A50514)
Gleaner R50...
