Backhoe backhoe pump PTO broke *%#!!
   / backhoe pump PTO broke *%#!! #1
YukonKing
Bronze Member
Whitehorse Yukon Canada
2021 L2501 FEL
Hey All,
So while trying to engage backhoe pump PTO it when pop crunch grind and now there is no discernable position and no function. So the question is do you have to pull the the hydraulic lift mechanism/tank off. And has anybody done this type of fix? What level does the tractor have to disasembled? Any input would be appreciated. "easy" "hard", split tractor? Things go "shhproyoing" and go flying?
   / backhoe pump PTO broke *%#!! #2
If you are talking about the PTO engagement lever at your right ankle ??
The book calls it a shift lump....... that may be broke?.
The hyd lift box does have to be removed. I don't think it is a hard job ....... just heavy!.
Look a section 6 here ...... http://www.ranchhandsupply.com/techstuffus/254le354ledrivetrain.html
Ronald
Ranch Hand Supply
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
