Backhoe backhoe question
   / backhoe question #1
rojo
I recently picked up a JD 970 tractor with a Bradco 8LD backhoe attachment. The tractor has a set of hydrualic fittings on the back of it that I believe are constant flow, one has a quick coupler, the other has a one foot hose with a quick coupler on it. I am quessing they are plumbed into the three point lift somehow. I can tell you that the three point rock shafts lift really slow if you do not hook them together. Can anyone explain this to me, and is it proper to hook them together or is this going to cause the hyd. oil to get hot? Thanks for any replies.
   / backhoe question #2
Welcome to TBN:D
What you have is called "Power Beyond", and it is indeed a constant flow of hydraulic fluid whenever the tractor is running. To prevent serious damage to your hydraulic pump YOU MUST COMPLETE THE LOOP before starting the tractor.
   / backhoe question #3
What Kenny said is right. You can break your hyd pump if they are not hooked together BEFORE starting your tractor. That is because our tractors use an open center system, you might think of it as an electrical circuit in series. The pump on our systems produces full volume all the time and oil flows through the system until it returns to the sump. When all the valves are in the neutral position then you have full volume flow, but very low pressure. The system does not build pressure until you move a valve and the pressure is diverted to a cylinder. All the valves in this kind of system are open center, that is that in neutral they allow full flow, through the valve.
In order to install hyd for a BH the circuit is cut and the BH valve is spliced into the system like a detour. When the BH is not connected, that short hose must connected to the QD so that the circuit is complete. If they are not connected then the circuit is stopped and that full pump flow has nowhere to go--the system will go to the maximum pressure that the pump can produce (Or if there is a safety relief valve, the pressure relief point). Since fluds cannot compress the pressure must go somewhere--that is when you find the weak link. Sometimes it is the pump shaft, drive, or pump body (they can split on the side), sometimes a line or seal. But there is going to be oil everywhere and it result in an expensive repair.
Please do keep them connected when you are not using the BH.
Mike
   / backhoe question #4
I just installed a bradco backhoe on my JD790 and I asked the Dealer a similar question. I was told that they must be hooked together whenever the tractor is running, and for the 3 point to work. I was told that the backhoe could be plugged into these lines but my flow would be restricted. The backhoe is supplied by the pressure side of these hoses but the return side is not large enough for the backhoe flow. A kit came with my backhoe to plug the return line into a drain plug under the tractor.
   / backhoe question
Thanks for the replies gentleman. It all makes sense.
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
John Deere 970 Cultimulcher (A52128)
John Deere 970...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
