Backhoes
   / Backhoes #1
eatenabean
Bronze Member
Alabama
MF 1643
I have a few large projects coming up. Fixing french drains on the house, digging about 30 stumps, and building 3 retaining walls.
I could rent a backhoe but i need to be able to work on my time.
So I come to ya'll.
What is the Best brand?
What is the best size?
3 point hitch or sub-frame mount?
   / Backhoes #2
Go w/ a subframe unit definitely. It puts all the stress on the tractor frame,
not the 3 pt. and rockshaft. I would first look at the OEM which in your case would be Massey. For shortlines, either Woods, Bradco or Wallenstein.
   / Backhoes #4
If your tractor is under warrantee, you should check into whether adding a non-OEM unit to the tractor will effect it in any way. Not just some salesman running his mouth, but look into it real good. Putting a hoe on a tractor puts a lot of stress on it, and you should spend a little time looking into this before you buy.
   / Backhoes #5
Two years ago we picked up a 1983 JD BH for $7200 when a new FEL for the 1976 MF. It is well worn but has a 7.5' FEL and 2' hoe and starts and runs well. Because we have 15 acres and I have physical limitations it is good to have around to lift and move things. Since putting a thumb on the hoe it is 10x more handy.
If I had to mount/remove a BH attachment it just would NOT happen. Being able to bushhog and grade without a FEL is nice in tight places and near buildings.
   / Backhoes #6
You should not consider anything but a sub-frame mount. I liked my Woods Groundbreaker BH-70x, but would go bigger next time. Warranty has been thrown around TBN before. A BH cannot void a warranty, but damage caused directly by it would be. That damage would either fall on the installing dealer since it wasn't done properly, or the bh manufacture if it was a design flaw.
I just traded my tractor with backhoe for a bigger tractor without backhoe. I agonized over it but then realized I can rent a mini ex for 1 full weekend a year for 20 years before it was cheaper to buy another one.
   / Backhoes #7
Local rental prices here:
Kubota U17 (7 1/2' zero tail-swing mini-ex) - $145/day
Kubota KX91-3 (10' mini-ex) -$185/day
Over the weekend is charged at a single day rate, with 8 hours run time. Units can be picked up for weekend rental after 2:00 PM on Friday and need to be returned between 7:30 and 9:00 AM Monday morning (except on a holiday weekend, like this one, where the return is due on Tuesday instead of Monday)
I had the KX91 last weekend .... and the U17 this weekend :D
By the time I'm finished, I will have dug 170' of 5' deep trench, and 100' of 2' deep trench .... installed 2 catchbasins and 6", 8", and 10" culverts .... popped a few stumps and trash trees .... prep'ed about a dozen or so planting holes and transplanted the same number of shrubs .... and done a few other things to boot ....
I do have a backhoe (BL4690) for my tractor - but the mini-ex's are so much more powerful/faster/more productive that for me it's a no-brainer .... and it frees up the tractor for other things .... like loader & box blade work and hauling the dump cart around.
   / Backhoes #8
So I come to ya'll.
If that's all you plan on doing, and you've got transportation for a nearby rental I'd suggest rental.
I got my BH because I wanted it and plan on using it frequently for SMALL narrow trail projects, and many miscellaneous projects at sites far from rental places.
I figured I would be renting one for weeks at a time at $500 a week, and having to transport it 30 to 40 miles one way.
If you REALLY want a BH I'd suggest a Woods BH80 w/ sub-frame.
   / Backhoes #9
I had the same quandary a few years back and bought a 4 year old mini for $12,900 instead of paying around $8,000 for a BH. Now there are many minis like mine for $2,000 or more higher than what I paid for mine. I looked into that when my wife had a garage sale and several people asked about buying it - I parked it at the end of the line so she could say everything up to the excavator is for sale. I told them that anything would sell for the right price but after I looked it up, I came back and said, "except the mini". Paid for itself easy in the 3 years in installing installing culverts, ditching, demolishing buildings, salvaging scrap iron, digging water lines, and planting trees. Narrow my track width and I can go places I can't get near with the tractor, plus no danger of flats. Think about it - it might be what you need, and in my area, if you decide to sell you get a lot closer to purchase price for a used mini than you do for a used backhoe.
   / Backhoes #10
I had the same quandary a few years back and bought a 4 year old mini for $12,900 instead of paying around $8,000 for a BH ..... Think about it - it might be what you need, and in my area, if you decide to sell you get a lot closer to purchase price for a used mini than you do for a used backhoe.
Did I mention I spent $8,000 on my 3PH backhoe ? :D
I really, really, really wish I had put that money towards a mini-ex .... would have been a far better use of resources ....
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
1264 (A50490)
1264 (A50490)
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
