Balast
/ Balast #1
richard_lee
huddersfield west yorkshire england
Kubota BX2200D
I read in my owners manual that it is benificial to stability and grip to use balast in the tyres. Experimented today with my spare set of turf tyres. Took a front one to the mechanics garage where I take my vehicles and we decided to fill it with water to see how much it weighed. I estimate that it holds approximately 30lbs. To fill it we put it on the tyre machine pressed one side of the tyre down which released it from the wheel then filled it with a hose pipe through this gap. We then inflated the tyre to seal it back on the wheel and turned it so the valve was at 12 o'clock, undid the valve and let the excess water out thus making it 75% full of water. The questions I need to ask are:
1) Do you put air in as well as water, if so what psi?
2) Do you put this liquid in the front & back tyres?
3) Have you a better method of filling the tyres?
4) Can you leave this liquid in permamently?
5) What % of anti-freeze to water do you use?
Thanks for any information!!!
Richard
/ Balast #2
Richard: Typically farmers fill the rear tires with a mixture of calcium chloride and water. The benefit is extra weight without freezing or adding rotational inertia (wheel weights can be hard on the drive train). Rear tires are usually filled to the top of the rim - so the center of gravity of the liquid mass is below the wheel center. Water will absorb several pounds of CaCl per gallon. There are special valve stems for putting the solution in - tire shops have them - and will fill tires for a fee. I think my 17.5x24 rears hold 55 gallons each - quite heavy. Front tires usually are much smaller and it's arguable whether its worth the trouble. Regarding inflation pressure, its the same as without liquid. Hope this is useful.
Someone here once posted a link to a site listing tire size and capacity - I've lost the bookmark.
/ Balast #3
Richard Lee,
As I recall, the owners manual specifically advises <font color=red>against</font color=red> filling your front tires. There was a discussion about this a while back, and this caution may no longer be warrented when using newer products. I would ask your dealer.
Others have used antifreeze, non-toxic antifreeze, and windshield washer fluid. How much you use would depend on the severity of your winters. I don't have any experience with any of these, and am still considering whether to "fill" or not. I am leaning toward non-toxic antifreeze because it is non-corrosive. Even though it isn't as heavy as calcium chloride, it will still add a considerable amount of weight.
/ Balast #5
Richard,
In your case, with the smaller front tire sizes, I would use windshield washer fluid... using your figures of using water adding about 30 lbs. translates to me a little less than 4 gallons {8 lbs./gallon}...
Windshield washer fluid over here in the states is 79 - 99 cents/gallon... so for about $8. total you could fill the tires and add about 60 lbs more ballast to your front end...
It's very cost effective, non-corrosive, clean and easy, don't need to use tubes {at an added cost}, and won't freeze... /w3tcompact/icons/smile.gif
{to only gain a few more pounds of ballast using Calcium Chloride and tubes wouldn't appear to be the smart way of going in this case}
Good luck Richard...
/ Balast #6
1) Yes, and run the same pressure as you would run with air only.
2) Some folks do; most don't; manual recommends against.
3) Yes, you can buy an air/water adapter at Tractor Supply Co., some tractor dealers, some tire dealers, etc. for less than $10.
4) Yes
5) Depends on how cold it gets; there's usually a chart on anti-freeze containers showing what percentage will protect to what temperature.
/ Balast #7
Bird--- Need your help. I can't find the air/water adapter at Tractor Supply Co. Any help? I would like to buy one so I can fill my tires. It looks easy and would work great.
Mike
<P ID="edit"><FONT SIZE=-1>Edited by burnickas on 11/08/01 08:33 PM (server time).</FONT></P>
/ Balast #8
Darn it, Mike, I just saw one at Tractor Supply awhile back, and it was in my old catalog, but now I can't find it in the 2001 catalog myself, and I really dislike what they've done with their web site. I'll let you know when I find it.
/ Balast #11
Try NAPA or any automotive supply. That's where I got mine. I think $6.
Keep the greasy side down.
Mike
/ Balast #12
Mike, I really don't understand why it isn't in the 2001 "Blue Book", but I threw away my 1997 catalog when I got the new one; however, I know they still had the air/water adapter with the other tire stuff in the store.
And yep, I buy my Power Service additive there, too.
/ Balast #13
Mike,
I hope those guys aren't on the safety committee where you work/w3tcompact/icons/smile.gif.
I think most people here would agree that rear ballast is tremendously important for stability when using a FEL, particularly on smaller compacts. I have done some calculations to estimate the c.g. (length-wise) with different loads in the bucket and different amounts of weight (or no weight) on the 3-point. Trying to combine the maximum loader lift capability with zero weight on the 3-point means that you're probably going to stand the tractor on it's nose.
The other arguments about loading up the front end too much, and about helping your rear-wheel traction (in 2wd) are valid too.
Rob
/ Balast #14
Mike, if you're using a FEL, picking up weight in front of the tractor, you need ballast (liquid in the tires, wheel weights, and/or weight on the 3-point hitch) to hold the back end down. Otherwise, you may need it for more traction for pulling ground engaging implements (plows, blades, box blades, etc.), but if you're only using it for mowing, tilling, and such, then you don't need ballast. It just depends on how heavy the tractor is already and what you're going to do with it.
